Old 11-10-2010, 04:05 AM   #26
kikkegek
kikkegek's Avatar
Re: Improve mileage 350 with Quadrajet
Originally Posted by INSIDIOUS '86 View Post
The problem in finding your timing tab might be a simple fix lol I think everybody us thinking of the timing tab on the side were as it may be the type. That has the tube in the middle of the timing chain cover look down the back of the water pump and the timing tab should be there
he man! thanks. I'll check that. Kinda hard for me, because I need to crawl under the car, but I'll do. I guess you mean under the engine behind the waterpump? or do I need to look from above?
@gchemist: no! I am sorry, I did not crank it. I'll try 2nite!
kikkegek is offline   Reply With Quote
Old 11-10-2010, 04:07 AM   #27
motornut
78K & 79C Jimmys
motornut's Avatar
from above
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-10-2010, 04:38 AM   #28
kikkegek
kikkegek's Avatar
Originally Posted by motornut View Post
from above
shouldnt you be asleep right now?
and any tips on how I (I am not a professional mechanic) could crank the engine? what do I grip to crank it? or better yet/ what do I use?
Old 11-10-2010, 04:47 AM   #29
motornut
78K & 79C Jimmys
motornut's Avatar
Angry Re: Improve mileage 350 with Quadrajet
yea kinda, but da police came a knockin some drunk hit my truck .....can't sleep now
John
Old 11-10-2010, 04:53 AM   #30
kikkegek
kikkegek's Avatar
he man! I am really sorry for you!
hit and run? man! thats not cool!
look pretty bad! good luck! and thanks for helping so far.
I'll check in again 2nite after I looked at my truck again!
Old 11-10-2010, 04:59 AM   #31
motornut
78K & 79C Jimmys
motornut's Avatar
take something to mark ,draw a line around the dampener ,chalk?to be sure you check all sides? lol
in the pic a small black line is actually a groove
bumping you may have missed your mark
chalk mark will be sure no miss
John
Old 11-10-2010, 05:00 AM   #32
motornut
78K & 79C Jimmys
motornut's Avatar
no they got him,impared
John
Old 11-10-2010, 05:09 AM   #33
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Wow! Glad they caught him!
Most of the damage is on the fender. Easy to replace. The may be saved but it's hard to tell. If the running board is damaged, you will probably have to remove them. Those are hard to find now. Paint scheme is hard to match.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-10-2010, 05:18 AM   #34
motornut
78K & 79C Jimmys
motornut's Avatar
the doors are shifted/buckled all around
John
Old 11-10-2010, 05:22 AM   #35
kikkegek
kikkegek's Avatar
good for you! make him pay! that A@#$-hole
Old 11-10-2010, 05:26 AM   #36
motornut
78K & 79C Jimmys
motornut's Avatar
from labourday weekend ...sept 6
John
Old 11-10-2010, 05:53 AM   #37
motornut
78K & 79C Jimmys
motornut's Avatar
well i can turn it holding/turning the pully and pulling the belt,
from the top
like if you have a bad tooth on the flywheel and/or starters stuck out
John
Old 11-10-2010, 06:04 AM   #38
kikkegek
kikkegek's Avatar
from the top
He Motornut. thanks! which pully do you pull? the balancer? or what? and can this be done with the car in P or should it be in N?
Old 11-10-2010, 06:06 AM   #39
motornut
78K & 79C Jimmys
motornut's Avatar
yup the pullys it's on,in Park
John
Old 11-10-2010, 07:58 AM   #40
kikkegek
kikkegek's Avatar
I am probably gonna need to try this from the bottom, because there is no way (I think) I can reach the dampener or its pullys from above.
well...as I said! I check back in 2nite and bring you guys an update! Hope I can talk my girlfriend into letting me try this before its dark!
this is what it looks like from the top! No way I can reach the pully's on the dampener from above!
My best bet is from the bottom. This is what it looks like from the bottom:
Old 11-10-2010, 11:18 AM   #41
geezer#99
geezer#99's Avatar
No need for moving that stuff by hand. Get a helper to bump the starter with the key. Just a click at a time.
Put some white paint on the mark when you find it. Touch up paint works or white out.
Fill the groove.
Old 11-10-2010, 04:22 PM   #42
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
If you can't move it by hand by pulling on the belts, or if you can't find a helper to bump the starter, there's a nut on the alternator that you can use. Just find a socket big enough to fit it and start turning it as if you were tightening the nut. The engine will move that way.
lindstromjd is offline   Reply With Quote
Old 11-10-2010, 04:46 PM   #43
kikkegek
kikkegek's Avatar
FOUND IT!!!!!!!!!!!!!!
hahahaha...I am a happy puppy!
what an impossible place! I can not find any reading on it in the dark 2nite. But at least its there.
Now I need to find out if the scale on these indexes is universal or if it is different from plate to plate? Anyone knows?
I am trying to get me a timing lamp. So this weekend I should be able to check the timing!
Old 11-10-2010, 04:59 PM   #44
kikkegek
kikkegek's Avatar
ok,
already found this picture. which must be the same:
the wide cut must be 0. And the side with the three points must the BEFORE and vise versa.
Old 11-10-2010, 05:00 PM   #45
geezer#99
geezer#99's Avatar
The big V is Zero. At the bottom of the V. The first high point to your right is 4*. Each point is 4*. The small lines are 2* each. Don't forget to unplug your vacuum advance when you check your timing.
Old 11-11-2010, 01:01 AM   #46
lindstromjd
Yup. That's it. And if you look closely enough, you can just barely make out the numbers for the timing marks. Clean it up real good with some carb cleaner; it works better than engine degreaser, but don't use it anywhere near paint that you want to keep on the engine.
Old 11-15-2010, 03:52 PM   #47
kikkegek
kikkegek's Avatar
I bought an Equus 3568 timing light. Tomorrow it will be here. Then I can start doing some serious check sin the engine ignition timing!
Old 11-17-2010, 05:49 PM   #48
kikkegek
kikkegek's Avatar
I am back!
and indeed, the setting was off.
pulled the vacuum loose and closed it off, had the motor running at idle, about 700 rpm
Timing was at 0 to +1....
loosened the distributor and turned it counterclockwise. I could hear the engine rev up. NICE!
Put the timing light back on it again and it is now set a about -10 to -11. Which is just fine on LPG I heard. went for a ride.
first connected the vacuum again, and no difference. No vacum advance. strange.
the vacuum hose is connected like the red line in the picture. disconnecting it does not change the rpm or anything. The hose can not be bad, cause that would mean I would be running a constant vacuum leak. and the engine seems to run OK. I wanna check later on using the other connection at the arrow. Would that be OK?
so...to be continued!..another step closer to better mileage!
Old 11-17-2010, 06:21 PM   #49
geezer#99
geezer#99's Avatar
Your vacuum is probably hooked to ported source. Ported means vacuum from above the throttle plate. Zero at idle but starts to supply vacuum once throttle opens. Try hooking to a full time manifold vacuum source to check your vacuum advance. You have a spot behind your carb that has a line with a screw in it.
Lpg likes lots of timing. You might need to turn your idle down since it's running faster now. Idle adjustment screw is on linkage on drivers side of carb.
Old 11-18-2010, 12:33 AM   #50
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
I don't subscribe to the "trash the Quadrajet and get something else" idea because a finely tuned Qjet will likely get you better gas mileage than the other brands. Don't overlook the importance of a carburetor rebuild. I'm not saying to start here, but a rebuild will definitely help.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
