Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-22-2010, 09:45 PM   #26
Gobbles
Gobbles's Avatar
Re: Help me select the right welder
Originally Posted by Mieser3 View Post
Is this pretty close to what most of you run as far as lpm? The set-up cd I got with my Millermatic suggested to run it around 25.
Hey, actually I run 15-20 that was a memory failure on my part! Usually closer 15 LPM. I used to run 25 but decided to lower it because my area has no wind and since I have had no problems. If you start to see porous weld issues then you can up the gas level back up. Running more gas won't hurt, I just like to be cheap with welding consumables, they add up so fast.
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
