#26 |
Re: need more stopping power. vacuum issue?
not a big deal on carbd engines u can throw the most agressive cams on carb engines and they are easily tuned to run try that on EFI good luck computers eaven after being retuned will not run appropietly. I am referin in particular to choppy as F@k idles wich are vaccum robin, but sick as f@k
#27 | |
Here is the cam card of the one I will be running. http://www.compcams.com/Company/CC/c...?csid=396&sb=2 Last edited by baclay9; 11-13-2010 at 09:00 AM. |
#28 | |
A quick test: 1 - start engine and let idle 2 - press brake pedal sharply and listen for a 'hiss' sound. That sound indicates you have some vacuum 3 - release brake and let engine continue to idle for a few seconds 4 - shut off engine and wait 10 seconds or so 5 - repeat step 2. If the system is working properly, you should still hear the same hiss sound. If you do not, then the system is not holding vacuum. Either the check valve is bad or missing, or the diaphram in the booster is ruptured or leaking. You should get at least 2 or 3 brake pedal pushes with vacuum boost assist before all the vacuum is blead away with the engine not running. Back to the earlier discussion on the vacuum can. If you are going to add one, it would need to be on the booster side of the one-way check valve. The vacuum can only adds extra 'capacity' to the vacuum system. It does not in any way generate more vacuum. All it can do is hold highest vacuum the engine can generate.
- Greg |
#29 |
wow, lots going on in this thread since yesterday! im not 100% sure of the cam that is in there. i might be able to get in touch with the previous owner but for right now i have no clue!
and im also not the most mechanically inclined person but i don't wanna throw money out the door for someone to check basic stuff ![]() |
#30 | ||
The whole thing seems to me like "too much cam" w/o having the surrounding systems "adjusted" to compensate for it. This could also include the torque convertor. If it is too tight, other issues get involved. He also may be lacking the compression needed to make the cam function too... My point about switching the vacuum line was more about the fact that it will not "use up" the available vacuum than the technicalities that get over many people's heads.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 11-13-2010 at 12:19 PM. |
