Old 12-02-2010, 02:28 AM   #26
harnalien
TruckincrazY
harnalien's Avatar
Re: Please help me get started!
I think I'll call Comp Cams and Texas Speed tomorrow to see what they suggest. I saw this one. http://www.summitracing.com/parts/CCA-54-418-11/. It has the 112 LSA so that should be nice and choppy. I think I want this thing to be a beast. The only thing, I noticed the operating range is 2000-6800. The other one was 1300-6300. I don't know if that means I'll have to keep it revved to get power or not. Another thing I'm wondering about is vacuum due to the power brakes. I don't know how much I need to keep brakes operable. Probably a dumb quesiton. I'm getting more excited because I think this is actually gonna happen. The shop is making it seem like it's not that big a deal to hook me up.
harnalien is offline   Reply With Quote
Old 12-03-2010, 11:13 AM   #27
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
you can run a vacuum cannister, or hydroboost if you think you won't be getting enough vac for the brakes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-03-2010, 12:26 PM   #28
swb85
On a budget like Fred Sanford
swb85's Avatar
You shouldn't need a vac canister or have to worry about power brakes with your plans. I run a waaaay bigger cam in a 370ci LSx (30* of overlap @.050") and don't have any problems with the factory vac assisted brakes.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-04-2010, 09:01 AM   #29
harnalien
TruckincrazY
harnalien's Avatar
That's good to know. I'm trying to keep this as straightforward as I can and don't want to do a bunch of extra stuff if I don't have to. The shop told me I can use my stock radiator and add some electric fans. I am also trying to find info on using the compressor in the stock location, but I can't find it. I know I've seen it somewhere.
Old 12-07-2010, 12:54 AM   #30
harnalien
TruckincrazY
harnalien's Avatar
Well Comp Cams got back to me today and recommended the following from their LSr series:
LS1 Camshaft - Hyd. Roller - 1500-6700rpm - Adv. Dur. 269 Int./277 Exh. - Valve Lift .607 Int./.614 Exh. - Lobe Angle 112 deg. - Competition Cams Part Number 54-456-11
I must say, that is much bigger than I thought they would suggest. This seems like it will be a pretty nasty cam. The thing I worry about is piston to valve clearance with this big of a cam. This will also increase the budget due to having to get dual springs or high dollar beehives. What are some solutions if there is piston to valve issues? I may have to keep looking if this cam makes me have to do a bunch of other stuff to make it work. Anyone have any thoughts?
Old 12-07-2010, 02:09 AM   #31
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
pretty close to mine...
I forget the adv. duration (272/281?).....but its 223/231 @ .050 .610/.617 lift 112 LSA
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-07-2010, 11:19 AM   #32
swb85
swb85's Avatar
That's not a very big cam AT ALL, actually just about the same specs @ .050" as GM's hotcam. You won't be anywhere near P/V clearance issues, and it'll have a mild chop at idle with great torque production.
Old 12-07-2010, 12:47 PM   #33
harnalien
TruckincrazY
harnalien's Avatar
Awesome! I guess I am thinking of it being big for a 350 cam. I like the numbers on this cam and the springs will be about 100 more than what I was gonna get. Thanks!
Old 12-08-2010, 12:35 AM   #34
Puglia10
do you want/need to upgrade your stall convertor?
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 12-08-2010, 01:23 AM   #35
68GMCCustom
there's a bit more lift there then the GM hot cam......
Kurt -
Old 12-08-2010, 04:12 AM   #36
Mr. 250r
Mr. 250r's Avatar
Im not sure if you picked mounts yet but like someone else said dirty dingo has a good reputation, I've been looking to do this swap myself except with 04 gto ls1 and a few good companies for wiring are currentperformance, speartech, nelson just make sure to research the companies you pick see what people say about them.
I don't know what engine your picking some ls are a little different on the accessories but for some relocation brackets in case you find out something won't fit try http://www.kwikperf.com/index.html
Mr. 250r is offline   Reply With Quote
Old 12-08-2010, 04:15 PM   #37
swb85
swb85's Avatar
Absolutely.....but gross lift has absolutely nothing to do with how a cam "behaves".
Old 12-08-2010, 05:47 PM   #38
harnalien
TruckincrazY
harnalien's Avatar
I don't think I'll have to upgrade the stall converter and I really don't want to. I just got this tranny from Phoenix transmissions in July, so I don't want to mess with it.
I was gonna get the dirty dingo mounts for their flexibility. They are also only about 30 bucks more than the transdapt. I am going to drop the engine in without ac at first, but when i can, i will add the kwik peformance bracket and sanden compressor. i am still debating the wiring options. it really depends on whether i get the engine with everything. if i do, i can save some money by going with one of the mail order tuners. i was thinking of the painless kit, but i like the idea of working with a stock computer so that if i need to go to the local speedshop, they will be able to work on it.
Old 12-25-2010, 04:53 PM   #39
harnalien
TruckincrazY
harnalien's Avatar
Holy crap, my wife bought me the camshaft for Christmas!!!
So it begins!!
Old 12-26-2010, 02:21 PM   #40
68GMCCustom
thats a good woman you got there!
Kurt -
Old 12-26-2010, 04:13 PM   #41
85burb
85burb's Avatar
So it begins!!
Thats a keeper right there. Mine did same thing but i got it few months ago. Was also my birthday gift.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-01-2011, 12:24 AM   #42
harnalien
TruckincrazY
harnalien's Avatar
Well I got my engine today! It's an '04. I got a DBC throttle intake to go with it. I also got a computer for an '02 engine. I have started narrowing down where to get the wiring harnesses. I am trying to decide whether to go with a painless kit or PSIconversions. Any opinions?
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
Old 02-01-2011, 12:51 AM   #43
85burb
85burb's Avatar
Have you looked at the holley kit. Just seen it on tv last week end. Pretty sure it is a plug and play type. I want to say it is about a grand. But only has like 4 wires to hook up. Congrats on the motor.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-01-2011, 10:18 AM   #44
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
are you keeping the FI? if so, check out TechRods and also PSI Conversion for your harness.
http://www.lt1conversion.com/products.php
http://www.techrods.com/
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-01-2011, 03:00 PM   #45
harnalien
TruckincrazY
harnalien's Avatar
Yeah I'm keeping it fuel injection. I was thinking about the Painless kit because they do free computer flashing when you buy one of their harnesses. I like the PSI prices though.
Old 02-02-2011, 02:10 AM   #46
Gordonr1973
Home Built '87
Gordonr1973's Avatar
I bought the Painless chassis kit from the cab back and I got the PSI wiring harness for the motor re-wire.
I called Jon at PSI about 5 times with different questions and he seemed to have all the answers I needed. Painless was okay to talk to but their direct price was $300 more than what I bought their kit for from Summit.
Plus Jon said he'd reflash my PCM for free (I pay shipping) in case I change my tire size later on --- I'll probably get it dyno'd and reflashed locally once it's on the road though.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
