Old 11-04-2011, 08:24 PM   #26
baggedbigblock
Re: My Build: Home Depot Machine
ordered gauges.
These gauges
Aviator trim rings
Original dash looks like this (not mine) mine is flat black
but for the gauge cluster I am making a template out of wood, then nail a copper sheet to the board with copper nails
Kinda like this
baggedbigblock is offline   Reply With Quote
Old 11-05-2011, 03:12 AM   #27
VA72C10
VA72C10
VA72C10's Avatar
Cool! Love the concept for the gauges!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-08-2011, 07:35 PM   #28
baggedbigblock
Got a little more serious today. Front end is off being sand blasted, once back on Thursday the lower arms will be cupped and the cross member will be raised 2". Bags will be installed and new motor and trans will go in. Next week the rear will be finished.
More engine work and lower alternator bracket
going to hand brass knuckles on the other panel opposite of the bottle opener. The pinstripe artist will paint, Play under the bottle opener and Work under the hanging brass knuckles. I am in the process of reupholstering the door cards.
my new material. Rebel side is mine, Colombian side is hers, the Kona one will be the shift boot.
Old 11-08-2011, 07:52 PM   #29
baggedbigblock
Made a final choice on wheels and tires
Old 11-11-2011, 07:31 PM   #30
baggedbigblock
got the shifter in the mail and installed it to see how everything works.
This came in too!
Old 11-12-2011, 02:48 AM   #31
McMurphy
McMurphy's Avatar
My wife was looking over my shoulder while I was catching up on your build and saw your grenade shift knob.
She laughed.
Then she said that if it all dont work out you could always pull the pin on the grenade and see what comes next.
I think it is time to watch "Uncommon Valor" again ....
LOL
Man that is a really low slung altenator, I am guessing this is going to be a fair weather driver for you?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 11-12-2011, 05:29 PM   #32
baggedbigblock
I was talking to my friend the other day, wondering how to explain to a cop when I get pulled over the grenade, brass knuckles, bottle opener, and burlap door panels. It may be a conversation I have to record on the phone's video camera setting, could be a fun one!
Old 11-17-2011, 06:53 PM   #33
baggedbigblock
He is working on the frame and suspension 2-3 days a week right now, when I go back out on Monday I pray it is sitting on the ground.
Last trip out was final assembly of the motor and bolting the trans on, still waiting on tubular motor mounts and crossmember to arrive. Cleaned up the engine bay fenders and radiator shroud. Leaving the firewall alone until we shave it.
Satin black paint but it is still wet
Old 11-17-2011, 11:29 PM   #34
Rednek13x
Rednek13x's Avatar
Cant wait to see your seat! Rest is looking great also
Rednek13x is offline   Reply With Quote
Old 11-21-2011, 10:02 PM   #35
DLOE65
DLOE65's Avatar
I like the grenade!
DLOE65 is offline   Reply With Quote
Old 11-21-2011, 11:06 PM   #36
McMurphy
McMurphy's Avatar
Milk crate seat for the win!!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 11-22-2011, 12:42 AM   #37
baggedbigblock
Super busy today. Here are some pics.
Raised crossmember
Old 11-26-2011, 09:46 PM   #38
baggedbigblock
More work today. Next the motor and trans go in, I have to install the new 700r4 crossmember its hitting the ground first, after that it should lay the front crossmember. I need to tub the front wheel wells that should get it 2-3" lower in the front. I just rested the front clip on top of the tires. Still waiting for the shortbed so we can cut the frame and install the 4 link.
Old 12-01-2011, 11:12 AM   #39
baggedbigblock
>>Update<<
Motor and trans are in, installing the mustang II manual rack and pinion, making wheel tubs for the front, running brake hard lines and running the fuel lines. Should have the wiring done in 2 weeks and fire it up!!!
Old 12-02-2011, 10:35 PM   #40
baggedbigblock
>>>>12/2/11 UPDATE<<<< With VIDEO!
You guys may like this update. Motor is in and sits at a nice angle back and sits low in the engine bay. For some reason I always like the looks of the motor at a slight tilt back. 700r4 is in with its new crossmember. You can see what happened to the new performance online motor mounts. I guess that's what happens when your truck isnt bolt on any more. I have stripped the cab and am working on rewiring the truck and replacing rotted rockers, lower doors, floor pans, and fenders. We have to tub the firewall since the tires are hitting, the new wheels are 255/55/18 and are .25" taller so I want to play it safe.
Enough blabber, here are the pics.
Shaved firewall, plan on shaving the inner fenders so everything is flat and smooth
rear setup, still needs 2" blocks to make the rear end lay frame and those will be in tomorrow. more tubular x bracing to be added.
VID: on schrader valves for now.
Old 12-02-2011, 10:54 PM   #41
VA72C10
VA72C10
VA72C10's Avatar
Looking good! Great progress!!!
Old 12-02-2011, 11:03 PM   #42
baggedbigblock
Thanks, I am on cloud 9 right now. I will be elated once I fire it up and hear that nasty cam while it sits on the asphalt.
Old 12-02-2011, 11:06 PM   #43
samuellg1977
samuellg1977's Avatar
Man, that thing looked evil when it lifted up from the floor - kinda slow and menacing, like it was waking up to kill something!!
Sam
samuellg1977 is offline   Reply With Quote
Old 12-02-2011, 11:09 PM   #44
McMurphy
McMurphy's Avatar
Sam
Wife even came in to watch. Good progress man.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 12-02-2011, 11:33 PM   #45
baggedbigblock
Thanks guys, been very busy. But I am determined to have it driving by Jan 10th. No special day, just setting a deadline to see if I can get it. I tell you I have no idea how Overhaulin does this in a couple days, and of top notch quality!!!! I guess 25 sets of hands 24hrs a day helps!
Old 12-03-2011, 11:45 AM   #46
protrash64
Resistance is Futile
protrash64's Avatar
Looking killer BBB!!!! I've seen front crossmembers pancaked but never notched into the frame. Does it use any of the original bolt holes?? How much drop did you get out of it?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-03-2011, 01:48 PM   #47
baggedbigblock
It was raised 2 in. the whole assembly moved upward so the lower and upper control arms are still the factory placement on the crossmember. It doesn't require notching the inner fenders for control arm clearance but the top outer fenders and firewall need tubed to clear a 28" tall tire. the bolt holes where used for reference but everything was welded in. Also the lower control arms being cupped probably added 2.5" more of drop and the 2.5" spindles are being used to keep neg camber at a minimum.
Old 12-03-2011, 05:14 PM   #48
protrash64
protrash64's Avatar
Thanx for the info......cant wait to see more updates!!
Old 12-03-2011, 06:50 PM   #49
chad64chevy
chad64chevy's Avatar
got a video of the rear bags yet?? your project is coming along nicely
chad64chevy is offline   Reply With Quote
Old 12-04-2011, 03:04 PM   #50
baggedbigblock
Yeah I have a video of the back, I'll upload to YouTube tonight
