12-03-2010, 04:55 PM | #26 |
Six in a row makes it go...
Re: GMC 305 V6 Rebuild with pics
You found the right guy.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
12-03-2010, 04:58 PM | #27 |
Looks like is spun a rod bearing, which means that rod will need work and more than likely the crank as well. Rods spinning a bearing no big deal crank spin a main that gets to be pricey as a line bore is needed etc. Make sure you number the rods and rods caps, as well the mains ...do not mix them up. As well I have found that a digital camera rocks for things like this you cannot take too many pictures. Looking good, I would not do any machine work or buy any parts until block is magnafluxed maybe even the heads as well... I do not think parts are going to be easy to find so take your time.
12-03-2010, 05:01 PM | #28 |
Oh believe me I have more pics than youd want to see. I used my customary way (way I was taught) of marking the side of the rod cap with a punch, and then the same side of the rod, that way number of dots and sides match up. But then I was happy to see that they are factory marked; on one side of the rod and cap it has a number stamped. Pretty cool.
The rod is going to need work and the crank is going to need a lot of work |
12-05-2010, 09:40 AM | #29 |
You have two good threads going on this.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-26-2011, 02:25 AM | #30 |
How's this coming? Any updates?
03-26-2011, 08:14 AM | #31 |
The account has been suspended so until that is resolved there will be no updates.
03-26-2011, 12:42 PM | #32 |
I didn't notice that. What a shame.
Maybe an admin will pop in and let us know what's what. Maybe it just needs downgrading to a regular account? |
07-15-2011, 10:56 PM | #33 |
1960 GMC Burb
Wish this would have continued since my V-6 will be getting some attention sometime soon..
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
11-08-2011, 02:24 AM | #34 |
This thread gets a lot of traffic so I thought I would post this up here:
305E rebuild specs: Piston clearance .0027 - .0033 Compression ring end gap .017 Oil ring end gap .015 Wristpin Diameter 1.24 Rod bearing shaft diameter 2.8107 - 2.8117 Rod bearing clearance .0015 -.004 Main bearing shaft diameter 3.123 - 3.124 Rear main shaft bearing diameter 3.1225 -3.1235 Main bearing clearance .002 -.005 Rear Main bearing clearance .0025 - .0055 Thrust bearing on #3
1963 GMC Wideside powered by a LH2 32v Northstar |
03-16-2012, 01:45 PM | #35 |
This thread gets alot of traffic because it was a great idea. If he just needs reupping his sub to the site I'd be happy to chip in to see some progress.
1Low4x4 - If you're on here by another name and need some $$ for this account to be re-enabled PM me and I'll get you back on track. |
03-16-2012, 04:02 PM | #36 | |
Just here to tinker
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
03-30-2014, 10:22 AM | #37 | |
Hey Fetch. Looks like the rest of the story can be found on this forum... http://www.truckmodcentral.com/forum...mething-12884/ |
