Old 01-16-2011, 11:20 AM   #26
FL71C10
Re: Complete SWB exhaust system
a few more
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 01-16-2011, 11:23 AM   #27
Hart_Rod
Hart_Rod's Avatar
Originally Posted by FL71C10 View Post
OK, here's some pics and some questions. First question is for you Rob. Is the motor in your truck mounted back a few inches? The exhaust hangars that you said was bolted to the back of the rear crossmember seems like it is 3 or so inches too far forward. I was wondering if maybe yours is mounted further back. I may have to have a muffler shop reweld the collector and add a few inches of pipe there.
My motor does sit pretty close to the firewall. I think previous owner used 6 cyliner motor stands instead of the factory V8 ones.
Looks like you will need to move it back and and reweld the collector.
Second question is about clearance. This is the first set of headers I have ever installed and they seems relaly clsoe to the motor mount stand and to the brake line near the crossmember. Is that normal?
What kind of clearance do you have? Mine were pretty close also. I think it's the nature of the beast. Here's a few pictures.
Hart_Rod is offline   Reply With Quote
Old 01-16-2011, 11:26 AM   #28
FL71C10
here's a few with the brake line clearance showing
Old 01-16-2011, 11:28 AM   #29
Hart_Rod
Hart_Rod's Avatar
My truck originally had drum brakes, I wonder if that could be the difference in the lines. I would probably just bend the line a little further away from the header and it should be OK. See Post above for the other questions.
Old 01-16-2011, 11:48 AM   #30
FL71C10
Yeah, I was planning on getting new stainless brake lines anyway, so I guess I'll route them a little further away.
I think it might be better to keep the sb motor stand and modify the exhaust so I don't cause a whole lot of other problems by moving the motor back.
Old 01-16-2011, 11:55 AM   #31
Hart_Rod
Hart_Rod's Avatar
I agree 100%, . Thanks again and take care.
R/
