Old 04-20-2011, 11:01 PM   #26
cadtorque
cadtorque's Avatar
Re: 295/65 R15 anyone running them? Will They fit on 8" ralleys?
I am currently setting up some custom 15x8" steelies with 295/65r15 M/T drag radials, and so far, I think it looks awesome. The truck has a 3"/4" coil drop, stock 15x5.5 fronts w/ 225/70r15. I'm going for the exaggerated hot-rod, but not quite pro-street look, and i think that rear tire is perfect. The truck currently has no engine, trans, or drive shaft either. It should sit at least an inch lower once carrying the extra weight. I also like the way they look on the narrower rim compared to the the 10" wide one. I like a tire to have a bit of a bulge in the sidewall. It makes it look muscular. Too bad BFG doesn't make the radial T/A in 285/70r15 anymore...
Wrong body style, I know... Just wanted to give somewhat of a frame of reference. I think that with the larger fender wells of the '73-'87, you could fit a 31x12.50r15. Hoosier makes a Pro Street radial in this size. Use a 15x10" with a carefully selected back-spacing and you're in!
'69 Chevy C-10, Hotrod farm truck. long bed fleetside
'71 Chevy C-20, Stock and original
cadtorque is offline   Reply With Quote
Old 04-21-2011, 09:02 AM   #27
SCOTI
SCOTI's Avatar
Originally Posted by cadtorque View Post
I am currently setting up some custom 15x8" steelies with 295/65r15 M/T drag radials, and so far, I think it looks awesome. The truck has a 3"/4" coil drop, stock 15x5.5 fronts w/ 225/70r15. I'm going for the exaggerated hot-rod, but not quite pro-street look, and i think that rear tire is perfect. The truck currently has no engine, trans, or drive shaft either. It should sit at least an inch lower once carrying the extra weight. I also like the way they look on the narrower rim compared to the the 10" wide one. I like a tire to have a bit of a bulge in the sidewall. It makes it look muscular. Too bad BFG doesn't make the radial T/A in 285/70r15 anymore...Wrong body style, I know... Just wanted to give somewhat of a frame of reference. I think that with the larger fender wells of the '73-'87, you could fit a 31x12.50r15. Hoosier makes a Pro Street radial in this size. Use a 15x10" with a carefully selected back-spacing and you're in!
Coker Tire Co makes the BFG 285-70-15 in it's Silvertown series tire.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-21-2011, 10:45 AM   #28
blazer2007
I run a 285/70 on mine
blazer2007 is offline   Reply With Quote
Old 04-22-2011, 01:40 AM   #29
taank
put these on today. they fit nice. might need to lower truck justa little. mt et street drag radials on a 15 x 10 4 inch backspace rim
taank is offline   Reply With Quote
Old 04-23-2011, 10:45 PM   #30
Maxxd07
Maxxd07's Avatar
A little off topic but I would love to see some pictures of the whole chevy "lil red express"! please!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 04-26-2011, 04:17 AM   #31
tazman87
tazman87's Avatar
295 on 10" rims
tazman87 is offline   Reply With Quote
