#26 |
Re: How to make suburban quarters
Wow you have mad skills , thanks for sharing !!!
http://www.cardomain.com/id/johnnye23 |
#27 |
x2, wish i could do that as i have a few areas needing attended to lol. i guess i could start by getting the right welder for the job but not enough money for that haha. oh well some day i will get to it. but anyways great job on that it looks good as new if not better
#28 |
Thanks guys. No hammer and dolly work on these but it can be done.
#29 |
Champagne Taste on Beer Budget
Yeah this is what me and my body guy have to do excatly to mine Suburban.
Not looking forward to that day. ![]()
Coming Soon: Project 1970 Country Truck |
#30 |
Coordinator of Synchronicity
![]() Join Date: Dec 2005
Very straight and smooth ...
And thank you for the patch panel idea, both of mine need help and this will truely help.
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be |
#31 |
You're welcome............
#32 |
"something witty here"
I have to do this exact fix. Thanks for the great idea how to fix it. I cant seem to find the bottom piece you used, or the tail light ass. Every one I find is for a lwb and wouldnt that be to short?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
#33 |
I actually found brothers makes the bottom section but still no luck finding the tail light. I cant find tri-plus either anymore.
#34 |
![]() Join Date: Dec 2010
Try LMC (Long Motor Company)
1972 C10 Suburban 1959 Austin Healey Sprite 1977 Datsun 280Z |
#35 |
What?
I'm going to move this thread to the burb build section, since it has great info that builders of burbs could benefit from.
Awesome metal work by the way!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#36 |
Certainly is mad metal skills!
#37 |
BlahBlahBlah
I really love checking out ebfabman metal work threads. And I think its cool he does this all with mig. So many people say you gotta have a tig to do this kind of work. He has proven them wrong over and over.
#38 |
Do you use the opposite side for the door skin?
#39 |
Wes at classic heartbeat should be able help with the panels. Wildstreak, I used a right and a left door skin. That way the more of the panel could be used. There is the door handle area to consider
#40 |
Thanks EB,
Was there a reason that you used two panels? The damage looked like one wouldve been enough to cover the area. I have similar damage, and need the lower 1/4 as well, did you just go the width of the lower 1/4 just to match? I would like to stay away from the marker lamp if possible.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 02-21-2011 at 10:14 PM. |
#41 |
![]() Join Date: Apr 2000
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro |
#42 |
Eb, I have a question....instead of using a door skin, can you use an extra door and cut it up? Curious if there would be any issues in doing it this way???
#43 |
DBear, I see no reason why you couldn't use what ever is available as long as you have good material to use. I go through my scrap pile all the time. Call it recycle. Make us green..hehe..
#44 |
![]() Join Date: Feb 2008
Thanks for the education. Much appreciated. That is very nice work..thanks!
#45 |
i know this thread is pretty old....but it is still inspiring for me. I had a question EB.... what kind of wheel or pad/ and grit do you use for finishing? The finished product looks so clean and shiny. Thanks again.
#46 |
Very nice work indeed, thankZ 4 sharing
#47 | |
The Older Generation
Looks like he might have used a grinder with 60 or 80 grit on the first two pictures and maybe 100 or 120 on the last ones. You just have to take it slow and not press too hard to keep it cool. You don't want to get it too warm and warp it... LockDoc
#48 |
That's some stellar work, I've purchases the patch panels for my panel quite some time ago. Just waiting on the welder fund to get bigger so I can start.
#49 |
![]() Join Date: Mar 2000
Glad I saw this post I can quit explaining how to do this in emails and direct people to this post instead. Also guys for repairs forward of the rear wheels on the drivers side you can do the same thing except use outer rockers 1-2 needed depending how much you need to repair with the top section cut off at the door opening body line to use for the lower section of the repair to get the correct lower body curve with the lip needed to attach the inner quarter panel and then weld the door skin section on to get it higher up the same as what was shown in the rear by Ebfabman
Paul |
