#26 |
Re: Your 2011 Plans For Your 60-66?
I plan to bring the parts that are currently sitting in the cab outside into the basement. I have some parts in a stall in the barn that also need to come in. I hope to make a dolly for the cab and put a tarp over the darn thing. I've got to decide whether to build a 2-wheel drive or stick with my original plan of a 4-wheel drive. I guess the main plan is to allow it to continue to age. Of course it would be cool to find some axles and springs to put under the frame, but I don't want to over-reach.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
#27 |
![]() Join Date: Oct 2006
install 1967 rear end ,front disc brakesand cruise it
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#28 |
Chevy Only Tx
Buy and install big brake kit,(drilled and slotted 5 lug) wheels and tires,finish body work,new front fenders, bumpers and air management kit.
Chevy Only Tx......... |
#29 |
Hmmm... install new rear bumper, new door locks, seatbelts and mirrors. Rattle can paint the box to match the front a bit better. Install the LS 6.0L/4L80 that I just finished pulling from the donor truck. Pipe c-notch the rear too.
#30 |
1960 GMC Burb
Just want to get that beast painted so I can bring it home. ( this week, I hope I hope I hope)
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner ![]() 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT ![]() |
#31 |
Battery, brakes and a windshield. Then drive it like I stole it!
#32 |
Front disc brake conversion w/ drop spindles, 2 in spacers and a CPP C notch in rear , swap in the 12 bolt rear diff out of my 77 blazer. Replace the missing drivers side window.
Would love to find a 3 duece intake set up too.
Betty : '63 Fleetside Longbed 350 w/ 4 speed CPP 3/5 drop with front sway bar. |
#33 |
Two if not all three of new wiring harness, bed floor and stereo system.
Happy new year everybody, '70GMCStep '65 Chevy C-10 '70 GMC Stepside |
#34 |
finish the 4 nagging things left to do then drive it as is. full daily by May is the goal.
Build Thread - Papa's truck build up |
#35 |
rebuild my carb (done01/02/10), replace the plug wires, finish bolting down the wood in my bed, change the 2 yr old oil filter....
#36 |
I hope to sort through my pile of parts and have enough to build a truck. I may try to trade my almost running 81 Short wide with 454/th400 for a running 60-66 c10.
#37 |
Put it back together, prime it, and drive it as much as I want.....
1982 K10 SWB 1987 V20 - Sold - Doh! |
#38 |
hope still working and put it back together and drive it
#39 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Mechanically sound.
Then I will move on to looks. For 2011 = get it to be a safe and dependable rig - that's it. ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#40 |
take the 6cly engine out,,,put the v8 305 (i have it )
just it will cost me too much coz i want to make the engine chrome full then finish the interior
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks --c30 1966 frame off 5 years restoration ; Finished; Chevy suburban 1958 restoration ( In progress ) 85 c10 "back to original project <Finished> " 81 c10 "back to original ( later) " 85 c10 cattleman edition lifted ( finished)> K1500 1989 full restoration ( soon ) S10 1991 in progress |
#41 |
1961 crewcab
alot of cutting welding, an engine swap, and maybe a brake job....
we'll see what happens. oh, and maybe buy a couple more trucks too.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#42 |
I just want to stop the transmission leak. thats been nagging me for months. Thats why I haven't drove it for quite a while.
#43 |
![]() Join Date: May 2007
2wd to 4x4 conversion.
Already have D-60 with 52" springs for the front. Corp 14 and 63" for the rear.NV4500 with a np205 and use the GMC V6 305 ( will update to a 401M at a later date )
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#44 |
I'll drive mine to Hoedown and Lonestar Roundup, maybe put my ZZ4 in sometime between now and then. Powdercoat my new instument insert,billet doesn't fit my truck...build a fan shroud. Mostly just continue driving the wheels off of it
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#45 |
Swap the body to the 'new' chassis & maybe even get to drive it . . .....
#46 |
Hopefully retire then I can actually work on mine
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#47 |
put more metal in than falls out.
#48 |
![]() Join Date: Sep 2008
Plan to rebuild the 350.....using oil somwhere, while the engine is out will repaint the engine compartment, also a complete brake job. After that if the cash cow holds out, hope to redo the interior
#49 |
My plans? Actually work on it.
More specifically, however, I hope to find a frame that we can steal from another truck to put under my '66. That's about the only goal I have set for it. Gotta keep it realistic as far as I'm capable of doing.
Betsy - 1966 C10 Stepside :: A very long-term work in progress |
#50 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Ummm, I would like to repaint it....unless the body shop will do it for free, I don't see it happening in 2011.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
