03-12-2011, 10:50 PM | #26 |
Re: Project Teal 72
Coming along real nice Doug!!! Now i need to get some wheels back on mine so we can go to the track at the same time.. What kind of b.s. are you trying to achieve on those 15x11's? If they turn out nice, i'll bring you another set to do lol!!!! (b.s.= backspacing)
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 03-13-2011 at 11:47 AM. |
03-15-2011, 10:01 AM | #27 |
Re: Project Teal 72
I got the wheels cut in two this weekend.
Hopefully I can get the bands from the steel shop this week. Credit for the chop saw idea goes to my dad.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! Last edited by dougminton; 03-15-2011 at 12:43 PM. Reason: more pics |
03-15-2011, 08:42 PM | #28 |
Re: Project Teal 72
03-18-2011, 09:58 AM | #29 |
Re: Project Teal 72
The original plan got scrapped because it wouldn't have cleared the brake drums.
I decided to just cut two and put bands in to widen by 4 inches Heres a couple of pics of an as yet unwelded 15x12
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
03-28-2011, 08:41 AM | #30 |
Re: Project Teal 72
I finally got time to tack one of the wheels together. Next thing to do is see how straight it is, hopefully less than .010 runout.
03-28-2011, 09:15 AM | #31 |
Still Learning
Re: Project Teal 72
Doug,
Looks like a real cool idea to chop the wheels. So, how did you true them up once cut? I would think you could chuck it up on the lathe and trim them straight pretty easy. Very interesting! |
03-28-2011, 09:27 AM | #32 |
Re: Project Teal 72
I ran the indicator on it while it was still on the hub after cutting and it was only out by .003
03-28-2011, 10:17 AM | #33 |
Still Learning
Re: Project Teal 72
That's really good! So, how did you secure the cutoff saw while cutting the rim? I guess you had some help spinning while cutting it? Very cool. Those rims are gonna be wide! One of a kind too!
03-28-2011, 10:34 AM | #34 | |
Re: Project Teal 72
It was a lot easier than I thought it was going to be. My dad timed the second one at 7 minutes.
04-11-2011, 12:31 PM | #35 |
Re: Project Teal 72
I made a little progress over the weekend.
Had to cut the wheel back apart.(too much runout .060) built some clamps to keep the pieces straight. got all the welding done,runout now is under .030 finally. started grinding the welds. 80 or 90 inches of weld, this is gonna take a while.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! Last edited by dougminton; 04-11-2011 at 12:31 PM. |
04-11-2011, 02:55 PM | #36 |
Re: Project Teal 72
Finally got the hotchkis sway bar,so me and dad installed it yesterday.
Now I dont feel like I'm falling over every time I turn a corner.
04-11-2011, 04:43 PM | #37 |
Still Learning
Re: Project Teal 72
Looking good! I like that sway bar. looks heavy duty.
04-11-2011, 06:48 PM | #38 |
Re: Project Teal 72
Nice progress. That rims are huge.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
04-11-2011, 07:08 PM | #39 |
67cheby
Re: Project Teal 72
nice work..never seen anyone widen there own wheels before....Impressive !!
04-12-2011, 12:58 PM | #40 |
Re: Project Teal 72
thanks and it's the biggest I could find 1 and 7/16.
thanks and just the right size for 28 x 14.5 hoosiers thanks and I just hope they'll balance good.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! Last edited by dougminton; 04-12-2011 at 12:59 PM. |
04-15-2011, 02:58 AM | #41 |
Re: Project Teal 72
04-15-2011, 04:00 PM | #42 |
PROJECT 7DEUCE
Re: Project Teal 72
Very interested to see how the wheels work out for you..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-25-2011, 12:46 PM | #43 |
Re: Project Teal 72
Just a little more progress.
I got all the welds on the wheels ground down smooth. Precision lines to follow to trim the bed. Then followed CROOKED lines with CROOKED cuts. And I found out tha M-H makes a drag radial thats big enough. 390/45/15
04-25-2011, 12:49 PM | #44 |
Re: Project Teal 72
Nice
04-25-2011, 04:34 PM | #45 |
One day...
Re: Project Teal 72
04-25-2011, 08:49 PM | #46 |
Re: Project Teal 72
Now I just need to get some sheetmetal and get back to welding.
05-04-2011, 12:58 PM | #47 |
Re: Project Teal 72
Alright, I got the wheels sandblasted and primed.
I bought some 5" sheetmetal and started tacking the wheelwell together. Tires should be here tomorrow.
05-09-2011, 09:46 AM | #48 |
Re: Project Teal 72
I got the tires mounted and balanced saturday.
one was nice and straight and just needed a little weight, the other took more weight than I liked but it still balanced. when I mounted them on the truck I realized that it needs to be lowered a little more.
05-09-2011, 11:42 AM | #49 |
67cheby
Re: Project Teal 72
looking good
05-09-2011, 12:24 PM | #50 |
Re: Project Teal 72
Thanks.
Now if it will hook up at the track maybe I can get that pesky 13 sec run in my sig replaced with a 12.??
