02-21-2011, 09:00 PM | #26 |
Re: My turn...83 shortbed 4x4 56k lots of pics
Looking good. Nice work!
Posted via Mobile Device |
03-02-2011, 10:12 PM | #27 |
Updates.....thinking of putting this tv i have laying around in. I whipped up a mount right quick for it and it doesn't look to bad.....and my dash turned out GREAT. Enjoy.
Last edited by daytonagp4; 03-03-2011 at 11:14 AM. Reason: My pictures keep disapearing......don't know why |
03-09-2011, 12:41 AM | #28 |
Pictures fixed!!!!!Sorry.
03-10-2011, 02:15 AM | #29 |
Bumper is close to being mounted and the wiring is finished in front.Does anybody know if i can use the 79' bumper mounts on the newer 80's bumper. My frame is 79 and bumper holes don't line up.
03-14-2011, 12:57 AM | #30 |
Hood is done.....hand built 4" ....made it from the stocker. With my work and my painters work we have around 30 hrs in it lol said and done cost me 400.....still cheaper than buying one
03-15-2011, 02:21 AM | #31 |
03-15-2011, 11:13 AM | #32 | |
You can get the newer mounts and cut off the older mounts which are made on the frame. Or are you talking about the reinforcement angle pieces? The hood looks KILLER!! very nice work on the truck man! My opinion on the tribal or demon graphics is "less is more" understated subtlety will look better, and not distract for the truck.... maybe some ghost graphics? and it would kinda tie in with your theme.
CHEVY ONLY |
03-15-2011, 02:33 PM | #33 |
All the bracing haha i've red a few things talking about the horns...do i have to completly cut off the horns and weld in new? Is there any way to mount it with a diff brace? the bottom holes will line up but nothing else. And as far as the side braces im lost. Do i need to make new ones? Thanks
03-15-2011, 09:08 PM | #34 |
The 73-80 frame horns are formed with the holes to mount the bumper built in.
The 81-up frame horns are shorter and basically cut off. They use a bolt on bracket to mount the bumper. You need to find the 81-up brackets and side braces. Then you will see how much to cut off of the front of the frame. Drill new holes for the brackets and side braces and you are golden Posted via Mobile Device
CHEVY ONLY |
03-16-2011, 10:05 AM | #35 |
Hood looks sweet man!
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 |
03-16-2011, 11:21 AM | #36 |
^^thanks.....and Joe, I have the bracing for the front and i see where to cut the horns but as far as the side bracing i don't think they will work. I'll do some messing around and figure it out. Thanks for the info!!!
03-18-2011, 11:41 AM | #37 |
Man you read my mind with this build. I love the stance of it. It is absolutely awesome. I love what you did with the hood. Great Job.
03-20-2011, 12:59 AM | #38 |
Thanks......it really sucks right now cuz i'm so close to getting it done....well driving and i'm out of $$$.....so i have to wait.
03-21-2011, 09:32 PM | #39 |
how much lift is on this truck. It sits perfect
03-21-2011, 10:38 PM | #40 |
When i got it i was told 9" springs in the front and there are 5" blocks in the back. Never measured so not 100% sure. But the poly mounts lift it a little too. Like 1/2 inch or so.
03-23-2011, 11:24 PM | #41 |
NIce build and DAyyyyMN you did a nice job on that hood.
04-01-2011, 09:15 AM | #42 |
just ordered my brake lines, fuel line/pump, new fuel tank and sending unit, and some other odds and ends!!! looks like i'll be busy next couple weeks!!
04-07-2011, 12:04 AM | #43 |
my buddy works at a CNC shop he's cutting 4 of these for me....custom shackles |
04-09-2011, 02:59 AM | #44 |
Got most every thing outside cab wired up, looks good the way my buddy did the wiring. I was able to hide everything very well computer sits behind the dash. you can only see like 3 wires. I still need to wire up the truck power and some other things under hood but should be done this weekend with that. Brakes are mostly done, ordered my rear rubber line...when that's in it's done. gotta pop the water pump back off and get the new pully pressed in too. Anyway off to bed ....enjoy! Last edited by daytonagp4; 04-09-2011 at 03:02 AM. |
04-11-2011, 09:16 PM | #45 |
6>8 Plugless........
Very nice! Your hood looks sweet! On your bumper brackets for the outer ones, too bad you can't take the older ones and cut them in half. Then take the newer ones and cut them to where they meet where you cut the old ones and weld them together if you know what I mean.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-11-2011, 09:42 PM | #46 |
haha i thought the same thing but they are WAY to differant.....good thought though
04-13-2011, 09:05 AM | #47 |
Man i love your build when i first got my truck i wanted a 4 wheelin bang around rig then after my i blew the rearend up into pieces i wanted to make it a show truck haha. Even though my build page is kinda slow yours is very inspirin!!
85 custom deluxe 4x4 4 speed 350sb |
04-17-2011, 10:05 PM | #48 |
Well after countless hours of work and thousands of dollars 4years later i hear the truck turn over!!!!! Not running yet, don't have the PS fbody mani yet and i still need to finish my fuel system. But i'd say another couple hrs worth of work and this puppy is ganna run!!!!
05-01-2011, 07:01 PM | #49 |
IT'S ALIVE!!!! aLIVE I SAY!!!... Got it running today....holds an idle pretty good considering the exhaust isn't built and the o2's aren't hooked up. But it runs!!!!!
05-01-2011, 09:44 PM | #50 |
I forgot to ask....anyone know where to get the VSS sensor? Something that screws into my tranny and changes mechanical into electric pulse?
