04-27-2011, 09:23 PM | #26 | |
Re: Homemade Serpentine Brackets
I'm trying to get an updated model that shows a little more information. But I'm pretty new to that program I'm working and it's not going as fast as I would like The purpose of this bracket system was to have the nice clean look of the March Performance kit and not spend a fortune on it. I am willing to dedicate the time and work to design a bracket I'm happy with, so I will just keep adjusting it till it's perfect. This isn't going in a truck that I will be racing with, but you never know I might use this design on some other motors as well.
Jeremy 1965 Chevy c10 Short Stepside Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=410658 |
04-28-2011, 07:00 AM | #27 |
You heading in the right direction. On the cost side using the stock parts that are in the junk yards by the thousands should be considered. Like I said in the first post using a long pump, the stock crank pulley and water pump pulley along with the stock power steering pump and bracket would save you a ton of work and reduce your parts count. It gets all those parts in the same plane and just leaves you the alternator and ac to match to that distance. Have you though about the belt routing?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-20-2017, 06:42 PM | #28 |
Finally got back working on this bracket. I thought I lost all my drawings after my computer crashed, and kind of gave up on the whole project. Ironically, I work in a metal shop now and run a CNC laser, which gave me the idea to see if I could dig up some old drawings deep in my emails. Luckily, I did find some and they weren't far from ready to start prototyping.
A few days ago I cut my first prototype of the bracket out of thin 16 gauge steel to see if the mounting holes to the engine block were going to line up. [IMG][/IMG] The mounting holes weren't far off and I decided, after a few modifications, to go ahead and cut a second bracket. I stacked multiple layers of metal to get the desired thickness of the front and back brackets. [IMG][/IMG] I'm a little off on mounting holes for the A/C compressor and have to change the shape of the bracket a little bit, but every step is getting closer and closer to the final product. Having the CNC makes it a lot easier to get through prototyping! [IMG][/IMG]
02-20-2017, 08:31 PM | #29 |
Moderator
Good work, very interesting.
