Old 01-23-2011, 10:43 PM   #26
Leadfoot Lambert
Leadfoot Lambert's Avatar
Re: driveshaft question
I decided to buy the above kit and save the hassle, and I saved $140 over buying the parts individually
Leadfoot Lambert is offline   Reply With Quote
Old 01-24-2011, 12:47 AM   #27
Captainfab
60-66 Nut
Your truck has had a '73-'87 front suspension installed. I agree with Ron. I would have just used what you have there for motor and trans mounts and spent the $140.00 elsewhere. Those are what I prefer to use in my trucks.
Originally Posted by Leadfoot Lambert View Post
It has a coil spring rear suspension, so it should be a Chevy chassis. It is so true about parts being swapped around, so far I have found several 1960 parts on my 65 like the grille,and tail lights and maybe even the whole bed, I still haven't figured out if the front suspension has been swapped or if someone just swapped the spindles as it has 5 lug disc brakes up front. As soon as the snow lets up a little I will check the vin number on the frame to see if it matches the cab.
Old 01-24-2011, 10:13 PM   #28
Leadfoot Lambert
i hope your right because that will be one less thing I have to do!
