Old 03-30-2011, 09:24 PM   #26
chopsspcc
Thumbs down Re: 55-59 CPU Rear axle Flip Kit
hey Dave K, what all did you do to flip the axle? what did you do to lower the front?
Also, does anyone have any stock wheels for one of these trucks...I want to paint a set. This truck has some nast chrome wheels on it. Well, not nasty. Just fugly.
chopsspcc is offline   Reply With Quote
Old 10-16-2012, 11:02 PM   #27
NW Task Force
NW Task Force's Avatar
Originally Posted by michaelnolimit View Post
There are a couple of reasons for flipping the shackle.
#1 By flipping the axle we lower the truck about 7 inches. When you flip the shackle hanger your actually going to lift the truck about an 1 1/2.
So if you want it as low as it will go dont flip the shackle hanger and remove the bumpstops and install a small c notch.
#2 We also do this to make the truck ride smoother. If you look at the stock style shackle hanger it is designed to carry a large load AKA a load bearing suspension. By flipping the shackle hanger we are duplicating a passenger car syle leaf spring which is a progressive supsension. Therefore the truck rides smoother like a passenger car and not like a truck that can carry two tons of hay.
Has anyone else on the board tried this? I am seriously thinking of doing it to my 57' It looks like the rearend will have plenty of travel. I was worried that "C" notching would have to be done in order to run the axle on top of the spring perch. I'd be interested in seeing more pics of this setup. I am using a similiar rear...... 83' Trans Am/factory discs & posi.
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 10-16-2012, 11:34 PM   #28
youngsta
I have tried it. The truck that is documented here is mine. Rides very smoothly and have yet to bottom out. It is not c-notched or boxed and I have uncut rubber bumpstops. The real test will be putting my Harley or a crate motor in the back. I suspect it may bottom out or rest on bumpstops. I have yet to have a heavy load to see.
youngsta is offline   Reply With Quote
Old 10-16-2012, 11:44 PM   #29
NW Task Force
Wow! It is cool that I can talk with the person who owns the truck featured in the original thread. Do you have any other pics of your rig? I wanted to see the overall "stance" on flat pavement. What about the front.......any lowering done to it? Thanks! awesome truck!
Old 10-17-2012, 12:13 AM   #30
youngsta
Ask and you shall receive.
Old 10-17-2012, 12:17 AM   #31
youngsta
And another.
Old 10-17-2012, 12:31 AM   #32
youngsta
Truck was star of thread called Camaro clip 55-59 No Limit style. And 55-59 bolt on brake kit. I'm using 2" inch drop spindles ride height is static handles terrific. No Limit has been doing these trucks for many years and they will always give you "safe" and expert advice.
Old 10-17-2012, 08:43 AM   #33
Wheelie
Whats the width of that axle outside to outside of hub? I have been thinking about getting one of those rear ends.
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 10-17-2012, 07:37 PM   #34
youngsta
1986 camaro rear end 62" axle flange to axle flange.
Old 10-17-2012, 07:39 PM   #35
NW Task Force
Sweet! Yes, I am familiar with the articles you are talking about. I really appreciate the pics! The ride stance looks good. I will be doing this axle flip job soon. Thanks again!
Old 10-17-2012, 07:50 PM   #36
youngsta
Always glad to help.
Old 10-17-2012, 10:54 PM   #37
NW Task Force
Question Re: 55-59 CPU Rear axle Flip Kit
Oh, I forgot to ask you.........just want to clarify: When the spring perches are flipped, they are also moved 5/8" forward and new mounting holes are drilled? Just wanted to double check that before I drill.
Old 10-17-2012, 11:11 PM   #38
Choady
On the other hand...
If my axle is already flipped..
and I want the back of the truck a little higher...
by flipping the Spring perches, I can get the rear up about 1 1/2 inches?
A Sane Man in an Insane World
Choady is offline   Reply With Quote
Old 10-18-2012, 12:42 AM   #39
JumboAMONGus
JumboAMONGus's Avatar
wonder how low with some leafs removed , since missing some on my truck ,
JumboAMONGus is offline   Reply With Quote
Old 10-18-2012, 10:03 PM   #40
youngsta
This is my second 56. My first truck that I owned in the 1990s was done in this same manner. However some leaves were removed it loved to bottom out it was really rough riding. Your kidneys have been warned
Old 10-18-2012, 10:15 PM   #41
youngsta
That's pretty much it. But it probably wouldn't hurt if Rob or Michael chimed in with pointers.
Old 10-18-2012, 10:18 PM   #42
youngsta
If you do that I'm inclined to believe the bed will come down lower over your wheels.
Old 10-18-2012, 10:49 PM   #43
NW Task Force
Oh ok, hope I can find out. I have also heard of No Limit Eng. "drop" shackles for the 55-59 trucks (I might be mistaken).......were these used on your truck or just stock ones re-used?
Old 10-18-2012, 10:58 PM   #44
NW Task Force
I noticed that Micheal of No Limits has last been on the board in 2011....... looks like he is not on in recent times. One of the biggest things I am shopping for now is the axle conversion spring perches/bottom plates/u-bolts. I really want to know where to buy the ones used on Youngsta's truck. The bottom perch bracket incorporates the stock shock mounting design. Is this something No Limit sells as a kit or?
Old 10-19-2012, 12:46 AM   #45
meter swinger
meter swinger's Avatar
just PM rob. aka "robnolimit", he's on here alot. usually in the "make it handle" thread on the suspension forum.
meter swinger is offline   Reply With Quote
Old 10-19-2012, 01:33 PM   #46
robnolimit
robnolimit's Avatar
Glad to see this being talked about. The numbers are the numbers. Flip the axle = 7" drop (on stock springs). If you flip the shackle assembly, it raises it 1 1/2" for a net of 5 1/2". The ride is better with the shackle flipped. It's only drill bits and bolts. DO IT !!!!
ps. by some teflon spring liner.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 10-19-2012, 01:43 PM   #47
JumboAMONGus
one question , how would you match the front to the rear end ,, if your going with stock set up , would the mono leaf springs do it or will it sit to low in rear ?
Old 10-19-2012, 09:40 PM   #48
robnolimit
robnolimit's Avatar
The front would need to come down 4" or so. Reverse eye mono, or Posies drop leaf would be close.
Old 10-20-2012, 12:11 PM   #49
vwjohnny
vwjohnny's Avatar
Interesting topic. I am considering flipping the axle axle for my '59 as we speak. My Posies front drops showed up yesterday. Unfortunately won't be installed for a few more months or as soon as I can finish the firewall and get the motor back in. Excited to see the stance and check the #'s to see if "the flip" will work for me. Thanks Rob... Some really good info here.
vwjohnny is offline   Reply With Quote
Old 10-23-2012, 12:50 AM   #50
NW Task Force
Question Where can I buy the kit?
Does anyone know where I can find/buy the spring perch kit shown in the picture? I would like to use a similiar kit because of the shock mounting arrangement (stock). Price & Place?
