#26 |
Resistance is Futile
Re: 64-66 Chevy Stock Gauges - Voltmeter vs Ammeter (Batt)?
This is looking good RoyL!!! Waiting for you to figure it out
![]() ![]() Yeah, squares are 73-87 body style.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#27 |
![]() Join Date: Aug 2010
Thanks for the insight to the Chevy truck vernacular . . .
I'll keep ya'll posted on finding one that fits. Roy
1965 Suburban Waiting on Time and Money |
#28 |
There is this alternative as well for all of your gauge face, people that have used this says it works well.
http://whitegauges.net/products/1964...ce-Gauges.html
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#29 | |
Roy
#30 |
I've kind of stalled on this particular project at the moment. I wish I could find the post regarding the gauge face printout. In reality, it wouldn't be that hard to just paint something on the face and use pinstriping or something to get the lines to look good. There really isn't that much of the gauge face showing on the outside of the cluster.
You're right about the glue. That might be all it needs. Last edited by SFTorange; 03-02-2011 at 09:38 AM. |
#31 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
From the 1963 GMC Accessories Book. Chevrolet Accessories book had it listed as well.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 03-02-2011 at 11:54 AM. |
#32 | |
Roy
#33 | |
I just bought a NOS Bat-O-Meter and a sun tach (less sender) I am in the middle of refurbing a 66 gmc dash and I think this will make it look a lot better. I am trying to use chrome paint to finish it off will advise how it works and looks after everything is finished. Company wanted $200.00 to vacuum chrome it but I think I can do is by soda blasting the plastic, primering it, painting with chrome paint and then clearing it. Worst case I have to send it to them to redo it. Kieth ![]() ![]() |
#34 | |
Cool, where you gonna mount the Bat-o-meter? Roy
#35 |
#36 | |
![]() But the needle travel was way more than I expected when I connected to the 12V Ign feed. Based on the other voltmeters I've seen, the resting point (Ign off) is far left and with Ign on, it should move near the center (~12V), and when charging, slightly past center (~13+V). ![]() Here's a pic with it hooked to a 9 volt battery, in the truck, it goes just past horizontal. ![]() Sooooo . . . unless I got a bad voltmeter, the travel on this one is too much to make it useful. There are 3 terminals on the back, only get positive needle movement when connecting 12V to the top left and then ground the bottom center terminal. Reversing polarity moves the needle slightly backwards. If I move the needle (it comes off the pin it rides on), so that the operating range is at the center, the resting point will be far left out of sight. May need to query one of the "Box boys" to see what their truck normally voltmeter needle movement is to see if what I got is typical. I assume it's not. I think a strap on Voltmeter hanging off the bottom of the dash looks good right about now . . . ![]()
1965 Suburban Waiting on Time and Money Last edited by RoyL; 03-20-2011 at 02:29 PM. |
#37 | |
Here's the resting position for the 80ish silverado voltmeter. ![]() And here's the needle position with a 12V battery connected. Looks normal. ![]() Here's the back side of it. Top terminal is ground, left is +12V. The other one (right), don't know-not used? ![]() The bad one didn't have any needle movement at all when connecting to the +12V (left terminal). Connecting to the other terminal (right) moved the needle way too far. What I didn't know was that it was the wrong one to use. Guess a wiring diagram for the newer Chevy would've clued me in, huh . . . I didn't pay any attention to the connections when removing from the donor . . . Lessons: Make sure ya know which connectors go to what to use, mark top and bottom before taking the faceplate off, mark the needle position before you remove it to take the face plate off. So I'll be taking this good one apart to mount in the dash. I'll let y'all know something later. Roy
#38 |
Well, fiddlesticks . . . Got this one all ready to go in the dash and did final check on the needle to make sure it was clear to move and SOB, it quit working!
![]() Failed same as the other one, nothing on 12v side, big needle travel on the other.
#39 |
Royl I`d be sayng more that fiddlesticks....LOL...maybe its a wiring issue particular to our trucks that keeps burning them out. We`re still watching this.
#40 | |
Before I do anything else, gonna see if I can find a wiring diagram for the 80-something chevy trucks, see if the other terminal on their V-meter is used for anything.
#41 |
Scrapper 1
I'm more of the stock kinda guy i've used my stock gauge cluster for the last 20 years in the scrap metal hauling business and after i rewired my whole truck with M&H factory repop wire harness Not one problem
#42 |
Yeah, sometimes, if it ain't broke, don't fix it, works just fine . . .
#43 |
Well there is some thruth to that, but if you`ve ever had a harness fire due to a amp gauge/voltage regulator you`ll never have another one. I lossed a harness in a `62 409 back in `69......man what a mess....
#44 | |
So put it all together just like it came out the donor truck and used a modified after market guage bracket (U-shaped with rubber gromments) to hold it in. Used a piece of that gas tank filler hose I had leftover for a spacer, ~5/8" thick was about right. It happened to be the right ID to slip over the guage. I used little dabs of black weatherstrip adhesive to hold the orig. gauge face on the donor guage. When engine is running, the needle is a little too far over center, so I may tweak the needle postion so it's operating range is normal. Here are some pics. On to bigger and better things, now! ![]() ![]() ![]() ![]() ![]() voltmeter coming out of a 1980 Chevy Silverado. ![]()
#45 |
Cool Roy .....I will be making this change as soon as I get a chance......
#46 | |
#47 |
be sure to read this as well, shows a better way to retain the meter with tabs and clamp. Should be enough room for a hose clamp . . .
http://www.persh.org/pickup/TachDash.htm
#48 |
Hey Roy,
Could you post how you wired up the gauge? It's obviously pretty simple, but there were three studs on the back of the gauge and I wasn't sure exactly how to hook it up. |
#49 |
Yeah, pretty simple.
facing the rear connectors on the back of the gauge 1. right rear (from back of guage) post is not used, see empty connector from '80 silverado dash picture in previous post. 2. Top center post is ground 3. left post goes to your +12V switched wire. I used an unused pink wire from the autowire harness in the truck already
#50 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I found this thread by searching the forums for using the original ammeter space and replacing with a Voltmeter.
Good job on this. I had a bad dash fire back in 84/85 when I had my old 65 before. I'm going through the wiring now, and all evidence points to the ammeter.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
