Old 02-07-2011, 09:37 PM   #26
NW_Ryker
Re: Body mount questions
Your right. I'll have to trust the body man on this one. I'll make sure and check them before I do any serious driving.
NW_Ryker is offline   Reply With Quote
Old 02-07-2011, 11:45 PM   #27
Critter
Future TOTM Winner
Critter's Avatar
The bolts are welded to the tub so to remove them you basically have to ruin them with a grinder. The other option is to lift the body as a complete unit, swap the mounts, then lower it straight down as a unit. That's the way the factory did it but with machines. The problem is if/when you need to add a spacer to just one or two bolts, you have to completely lift the body again straight up and repeat, etc. Basically impossible, a waste of time at best, just get new bolts.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-09-2011, 12:44 AM   #28
1971k567cam
1971k567cam's Avatar
So i just did the same thing on my new to me 71 blazer. I put energy suspension body mounts in and now door hits at top of wing window and some at latch area. So if i read the diagram right i need to add shims at body mount at front and rear of door to get the body to flex up right and it will give more gap?
1971k567cam is offline   Reply With Quote
