03-10-2011, 09:01 PM | #26 |
Re: Like I needed another one of these things....
sure buy those rims and send me your steelies!
03-13-2011, 01:27 AM | #27 |
Loading.....
Weekend update from M7:
Added a Lokar shift linkage, swapped the rear bumper from my Blazer, transmission fluid change, new water pump, swapped new-to-me eyebrows, chopped off rear exit exhaust, removed heater plenum and associated junk, aligned the grille shell, added new beefy ground straps to engine / cab, replaced pitman arm and did a CLR trial run on the paint patina. I'm taking Sunday off because I'm tired.
-M7 '69 SWB GMC 5.7 EFI 69 C/10 SWB patina survivor 71 GMC K20 '72 K5 1-ton gear 468BB 86 K30 GMC High Sierra C&C Single Cab '96 SWB Single Cab 5.7 99 SWB Z71 Single Cab '00 SWB Single Cab 5.3 '01 K2500 Yukon Safari 6.0 06 2500HD Single Cab C&C Duramax 4x4 '08 1500 crew '11 2500HD Single Cab Duramax 4x4 |
03-13-2011, 01:37 AM | #28 |
PROJECT 7DEUCE
Truck is really comming along nice work..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-13-2011, 08:57 AM | #29 |
its all about the +6 inches
the CLR thing is pretty cool huh?
Truck is lookin bad ass! |
03-20-2011, 02:10 PM | #30 |
Loading.....
Smurftastic.
03-29-2011, 10:38 AM | #31 |
Loading.....
Here are the embarrassing before pics of the rusty floor areas. One spot under the cowl needs attention as well.
I have since plasma'd out a few spots and sprayed it all with ospho for rust treatment. Before the rockers can go on I'll have to repair the cab supports which means removing the clip. If the clip is off then might as well remove the motor / transmission and so forth.... ugh.
03-29-2011, 10:39 AM | #32 |
Loading.....
More:
03-29-2011, 10:41 AM | #33 |
Loading.....
Oh and I am not the hack that removed the rockers in such a sloppy manner. :/
03-29-2011, 10:50 AM | #34 |
Insert Title Here
cool truck
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
07-25-2011, 10:53 AM | #35 |
Loading.....
My floorboard rust repairs are almost done - just need to pull the front clip, replace the pass lower pillar support and weld in the passenger rocker panel.
I went ahead and laid down some rust cap paint, then seam sealer then topped it all with sound deadener. It runs from the cowl all the way to the line just below the upper gas tank mounts. Already a vast improvement over the rattles and engine noise. I have carpet, new door felts and floor vent seals to install next - Hopefully it'll be tight enough to keep the dirt dobbers out of there while it sits around waiting to be worked on.
08-08-2011, 10:56 AM | #36 |
Loading.....
Floor repairs finished
rockers on encapsulator painted top, bottom, cowl and inside doors seam sealed floors and cowl installed new felts and door rubber slapped on door panels / arm rests refurbished the floor vents I like how the doors close now. Here's a video of an open / shut: http://tinyurl.com/3s88hyk
08-08-2011, 11:50 AM | #37 |
LOOKING GOOD!!!! I wish had a truck that nice to start with.
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
08-08-2011, 01:22 PM | #38 |
Looking good! I like the stance. Austin huh....I'll see you around I hope.
08-08-2011, 07:53 PM | #39 |
I may have a fairly good front bumper.
08-08-2011, 09:01 PM | #40 |
VA72C10
Nice progress!!!
Looking for a 67-72 swb or blazer project in or around VA. |
08-08-2011, 09:46 PM | #41 |
Looking good!!!!
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD 1970 Chevy Nova - Street and Strip Project 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
08-13-2011, 07:42 PM | #42 |
Loading.....
Made a a tad more progress today -
primed my drip rail (seam seal tomorrow) added a transmission mount (PO had a chunk of 2" square tubing in there instead) touched up other seam seal areas underneath added my new to me GMC fender emblems took some current pics I also found some rebuilt 062 vortec heads on craigslist that I'm thinking about buying myself for my birthday.... Then I can install the Edelbrock fuel injection, serpentine setup, 700-r4 and other goodies that I've got waiting for deployment. Too bad I can't do *this* 5 days a week and sit in a cube for 2.
12-04-2011, 12:53 AM | #43 |
Loading.....
Update:
Pulled the front and rear glass to touch up the seams and add CST trim. The dash is sanded and cleared to give the worn look that the outside has - maybe a tad too far but I can always cover it later.... Whatchu think? Glass install was less than smooth but it's at least done now. Thank goodness this is a patina truck and not a show truck or I'd be in jail for breaking the fingers of the install guys. Grr.
12-04-2011, 12:54 AM | #44 |
Loading.....
Oh, and on a side note, the glass guys were EXTREMELY confused at the concept of having a truck all updated underneath with a rusty old faded exterior. (mission accomplished)
12-24-2011, 04:08 PM | #45 |
Loading.....
Picked up a Vortec donor truck this week. Merry Xmas to me!
'98 Suburban 180k with a busted transmission - $1100 I'll vent some holiday aggression on the scrapping process.
12-24-2011, 04:23 PM | #46 |
Trucks looking awesome, keep up the good work.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
12-24-2011, 04:48 PM | #47 |
Loading.....
Tow-tow
12-24-2011, 05:36 PM | #48 |
Old Skool Club
The burb may have some resale potential on the 88-98 parts board.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-24-2011, 06:38 PM | #49 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by 70cst; 12-25-2011 at 01:02 PM. |
12-24-2011, 11:39 PM | #50 |
Those rims look really good, and hey I'd love to have a shop that we didnt have to heat all the time.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride Last edited by chevy88; 12-24-2011 at 11:46 PM. |
