Old 07-13-2015, 04:46 PM   #26
Heater63
Heater63's Avatar
Re: Jeep Door Stops
Bump.
I am missing the stop arm retaining brackets that mount in the door frame. Found the labeled bag with the screws but the brackets are missing Anybody have a source or a couple of extra ones for sale??
292 + TKO500
Heater63 is offline   Reply With Quote
Old 07-13-2015, 07:12 PM   #27
trooper61
Re: Jeep Door Stops
Originally Posted by Heater63 View Post
Bump.
I used the ones that came off the jeep.
trooper61 is offline   Reply With Quote
Old 07-13-2015, 08:57 PM   #28
BOE
Re: Jeep Door Stops
I found mine at the junk yard for $10 each. It was a long drive so I bought one with the rubber and one without. They both work well but the one rubber does not open quite as far. I would suggest the ones without the rubber but that is just my own opinion. I think the ones from the jeep pickup from the same years are the same also.
BOE is offline   Reply With Quote
Old 07-13-2015, 10:19 PM   #29
Lugnutz65
Lugnutz65's Avatar
Re: Jeep Door Stops
Ahhhhh my friend BOE. I have a quick mod for you if you still have the rubber style Jeep checks laying around. This tip is on my website and I have the rubber style on my 1965 C10 and it's all good.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-13-2015, 11:34 PM   #30
BOE
Re: Jeep Door Stops
@lugnuts. I will for sure try that out thanks
Old 07-14-2015, 12:16 AM   #31
McStuffin
Re: Jeep Door Stops
Bump.
http://www.ebay.com/itm/1984-2001-Je...0c70d6&vxp=mtr
McStuffin is offline   Reply With Quote
Old 07-14-2015, 02:37 AM   #32
Grizz1963
Grizz1963's Avatar
Re: Jeep Door Stops
This mod certainly works and gives you the option to choose your gap.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-14-2015, 12:49 PM   #33
Heater63
Heater63's Avatar
Re: Jeep Door Stops
Originally Posted by McStuffin View Post
Thanks McStuffin!! I will gladly buy those, rather than beat myself up looking for the old ones (that obviously got trash canned!)
I hadn't thought to look at Jeep! I found the GM part number and it crosses to Corvairs too, maybe some other vehicles? of that era.
292 + TKO500
Old 07-14-2015, 04:13 PM   #34
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Jeep Door Stops
Will those pins work on a stock door check? I don't have any.
Old 07-14-2015, 05:51 PM   #35
luvbowties
luvbowties's Avatar
Smile Re: Jeep Door Stops
Originally Posted by chevyguys View Post
Anybody know if the jeep door stops are available new. Part numbers?
Cheapest Jeep "replacements" that I found: Google for Dorman part number 924-148. Just bought 2 via Amazon for a tad over $75--s/h being free saved about $12 as compared to next cheapest I found. Good luck.
Sam
luvbowties is offline   Reply With Quote
Old 12-02-2015, 12:20 PM   #36
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Jeep Door Stops
So if you were to make the front ones slightly longer , that would be about perfect?
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-02-2015, 12:29 PM   #37
Lugnutz65
Lugnutz65's Avatar
Re: Jeep Door Stops
If you can find the Jeep front door checks with the rubber stop then THIS MODIFICATION will work very nicely to give you a normal opening for the door.
Old 12-02-2015, 12:45 PM   #38
ol_skool_chevy
Re: Jeep Door Stops
that's assume
Mark with Chalk
Cut with a torch
Old 12-03-2015, 01:25 PM   #39
Free Candy Inside
Re: Jeep Door Stops
Here is my panel truck with rear Cherokee stops.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 01-01-2018, 12:30 AM   #40
mfm3
Active Member
Re: Jeep Door Stops
This is an old thread, but I just changed to new Jeep door stops and have a question. The two detent positions are nice for tight parking lots and also keeping the door open when parking on a hill. The only thing I don't like is the noise they make as you open and close the door...sort of a creaking sound. Maybe they will get quieter with use. Anyone experience the same?
mfm3 is offline   Reply With Quote
Old 01-01-2018, 08:21 AM   #41
The Rocknrod
Moderator
Re: Jeep Door Stops
My brand new stock ones were making a noise like that I sprayed em with white lithium grease, seemed to do the trick.
Old 01-01-2018, 11:06 PM   #42
mfm3
Active Member
Re: Jeep Door Stops
Thanks for the tip...should have thought of that. I only have a tube of white lithium. A small dab and no more creaking.
