#26 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: Got some work done
Heres a little better pic.just trying to help.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#27 |
I agree with ratty.lengthen the lowers.shorten the uppers.easily fixed.
#28 |
you need to measure it before you do anything.
with the truck level the engine and trans should be at 3 degrees leaning back. dont measure from where the carb mounts because that is angled up approx 3 degrees to offset this. and the rear end should point up 3 degrees at ride height. |
#29 |
Looks good nice truck, like the way she just lays there, very kool.
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#30 |
![]() Join Date: Jun 2002
stance is looking really good. Looking fwd to a build thread showing progress. cajungragger is on track. Simply put, get your engine / trans installed, then with truck at ride height (very important), measure & match your pinion angle to your trans out put shaft angle. (example: if trans out put shaft angle is 2 degrees down, then make your pinion angle 2 degrees up) this will insure no drive line vibrations due to U-joint harmonics
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
#31 |
I went and checked the bars on the 4 link and they are adjustable top and bottom
Posted via Mobile Device |
#32 |
quick question what rearend are you running? what lenght wheel mounting plate to whell mounting plate? and are you running wheel adapters to mount the dodge wheels? thank you
#33 |
Im running a Ford 8.8 out of an Explorer. I am running wheel adaptors
