Old 03-17-2003, 10:28 AM   #26
wHATANERD
wHATANERD's Avatar
Cool Rear End and Core Damage
Blue Beard, The damage other than bolt on pieces ( fender, grille, bumper, etc ) seems to be limited to the front forks being slightly bent, luckly the bend is before the cross member and will be able to be straighten. The rear end is staying, I have ordered 6 lug rotors from Classic Performance which are for the 71 and up spindles. I'll keep everyone posted on the progress.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 03-18-2003, 03:32 AM   #27
wHATANERD
wHATANERD's Avatar
Thumbs up Progress reporton my 1969
Hello everyone, today got off to a slow start, I started cleaning up the cross member I will be installing, and removed the left A-arm, It will have to be replaced do to being bent, cleaning the crossmember took most of the day, however after dark started working on the van tilt column again, got it sanded and ready for painting tommorow, also cut out the holes for the netural start/backup light switch. If all goes well tommow will be pulling the engine and trans and taking it to a mechanic friend for a new main seal, and gaskets, also plan to clean and repaint while it is out. I will be reporting back tommorow with the progress again.
Old 03-19-2003, 02:09 AM   #28
wHATANERD
wHATANERD's Avatar
Cool progress
The engine and transmission were pulled, and will be taken to receive no seal and gaskets tommorow, with the engine off of the cross member I should be able to start the crossmember swap to add disc brakes. I've also got to come up with a way to repair rust damage in the upper portion of the fire wall. I keep this thread posted with the progress.
Old 03-20-2003, 12:15 AM   #29
wHATANERD
wHATANERD's Avatar
Progress is slower than expected
The engine and trans have been dropped off at the mechanics, and should be completed Friday. while at the mechanics I'm having the water pump, timing gear and chain, freeze plugs, and gaskets, I also dropped off the drive shaft to have a new carrier barring installed. When I got home preasure washed the engine compartment, and should start the crossmember swap out in the AM.
Old 03-22-2003, 03:31 AM   #30
wHATANERD
wHATANERD's Avatar
slow progress
Things are going slower than expected, T
Old 03-22-2003, 03:38 AM   #31
wHATANERD
wHATANERD's Avatar
OOPS
Sorry about that, anyway progress is going alot slower that expected, My engine should be ready by Monday, The new crossmember is painted and the 69 lower A-arm has a 72 ball joint pressed into it a will work fine, I have spend time to clean and touch up the fire wall and the frame with paint, tommorow I will be installing the new crossmember and start connecting the brakeing system, Oh today I also completed installing the tilt steering, went in beautiful. should mave more tio report tommorrow.
Old 03-22-2003, 11:37 PM   #32
wHATANERD
wHATANERD's Avatar
crossmember is swapped
Progress is still slower than expected, however I now have the 72 crossmember installed in my 69, and started connected brake lines, I also have repaired the rust on the upper portion of the firewall, and should have the engine reinstalled Monday
Old 04-15-2003, 10:23 PM   #33
wHATANERD
wHATANERD's Avatar
Cool Almost There
The only thing left to do is mout the grille, bumper, and hood, and she will be back in service. attached is a picture.
Old 04-15-2003, 10:24 PM   #34
wHATANERD
wHATANERD's Avatar
another Photo
Old 04-15-2003, 10:25 PM   #35
wHATANERD
wHATANERD's Avatar
yet another Photo
Old 04-15-2003, 10:30 PM   #36
Blue Beard
Blue Beard's Avatar
Nice, be sure to post photos outside when she pulls out...........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-05-2003, 04:00 PM   #37
wHATANERD
wHATANERD's Avatar
Smile It's Back
I've finally completed m Truck afte the Wreck, atteched are a few pictures on the end results
Old 05-05-2003, 04:01 PM   #38
wHATANERD
wHATANERD's Avatar
Photo 1
Old 05-05-2003, 04:02 PM   #39
wHATANERD
wHATANERD's Avatar
photo 2
Old 05-05-2003, 04:03 PM   #40
wHATANERD
wHATANERD's Avatar
3
Old 05-05-2003, 04:07 PM   #41
wHATANERD
wHATANERD's Avatar
another photo
Old 05-05-2003, 04:08 PM   #42
wHATANERD
wHATANERD's Avatar
final phota
