Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-19-2011, 04:54 PM   #26
clos69
Its Topless Season!!!!
clos69's Avatar
Re: how to CLEAN rust off
Yeah Lime-away is another form of CLR in a gel for toilet bowls...which I prefer the gel bcus you can apply it directly to the problem areas....I dont know about waxing it yet tho...
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 02-19-2011, 05:05 PM   #27
pinecrest
pinecrest's Avatar
I believe the idea is then to clear it, not wax it. Don't know how long it will last. This is what I've been planning to do to my '47 once I get all the mechanical stuff done, while the pocket book recovers.
pinecrest is offline   Reply With Quote
Old 02-20-2011, 10:33 AM   #28
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the idea is to remove the rust.
waxing it would hold back the elements... just not for a long time.
Old 02-20-2011, 11:20 AM   #29
Shane
Shane's Avatar
the secret is in the GREEN ScotchBrite pad ...
Shane is offline   Reply With Quote
Old 03-14-2011, 07:34 PM   #30
y5mgisi
Second Chance Program
y5mgisi's Avatar
Loving this thread so far! Anyone just happen to know if the red or green scotchbright pads are more "coarse"? I have a ton of red but no green.
y5mgisi is offline   Reply With Quote
Old 03-14-2011, 09:03 PM   #31
clos69
clos69's Avatar
I used the Rinso green pads bcuz i noticed they were more coarsed than the scotchbright ones....i bought them and the CLR at a 99 cents only store.
-Carlos-
The of America
Old 07-10-2011, 11:15 PM   #32
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I did this today. Took several years off Ole Yeller. Great tip.
Zoomin is offline   Reply With Quote
Old 07-10-2011, 11:33 PM   #33
VA72C10
VA72C10
VA72C10's Avatar
Looks great!!!! Any full on before and afters of the truck?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-11-2011, 12:13 AM   #34
y5mgisi
y5mgisi's Avatar
What method did you use? CLR and a green scotch brite?
Old 07-11-2011, 09:14 AM   #35
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Yep. Poured CLR into a bucket and diluted with water. Used a green scotch brite and used medium pressure. It leaves the surface surpassingly smooth, no scatches.
Old 07-11-2011, 09:17 AM   #36
Zoomin
Man of Mini-Talents
Zoomin's Avatar
It's 106 here, I haven't finished up yet. I will later this week when I get done.
Old 12-03-2011, 03:12 AM   #37
sigshooter
sigshooter's Avatar
any pics of the end result?
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 12-04-2011, 12:12 AM   #38
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Here's a few shots before and after...
Old 03-14-2012, 06:08 AM   #39
Dragun12
Dragun12's Avatar
now that is awsome something i'll have to remeber
Dragun12 is offline   Reply With Quote
Old 03-15-2012, 11:35 PM   #40
Trekster
Trekster's Avatar
What a great tip.
I have been used white vinegar to clean rust off of small parts. Soak the rusted parts in a jar of vinegar for a week or so and the rust either disolves or is easily wire brushed off.
Trekster is offline   Reply With Quote
Old 03-16-2012, 12:38 AM   #41
y5mgisi
y5mgisi's Avatar
I just picked up my CLR to try this out in the next couple weeks. Unfortuantly, this is my before... Fraid its going to take a bit more then CLR! But why not see what the CLR will do first right?
Old 03-16-2012, 02:50 PM   #42
y5mgisi
y5mgisi's Avatar
CLR Results. I cant say that it is a miracle cure for rust but it does seem to work pretty good! Im sure alot of it had to do with the scotch brite pad i was using but none the less. It took my roof from full on focked to manageable in less then an hour. Worth it to me!
Before and after shots.
This right here was seriously two minutes of scrobbing, tops!
I also have a video uploading on youtube but its fighting back.
Old 03-16-2012, 05:14 PM   #43
y5mgisi
y5mgisi's Avatar
Video up.
Old 04-10-2012, 12:20 PM   #44
jackson
i tride it on my 49 . it works but it comes back pretty quick. although my truck is sitting outside . if you cleared it . it might work
jackson is offline   Reply With Quote
Old 07-14-2012, 09:58 AM   #45
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
What part CLR to Water are y'all using ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-08-2012, 03:13 AM   #46
y5mgisi
y5mgisi's Avatar
I did 50-50.
Old 08-09-2012, 02:35 AM   #47
BigDan3131
BigDan3131's Avatar
Very interesting, I was told the stuff they sell at Harbor Freight works great too. Its called, Evapo-Rust. I will buy some and give it a shot. Someone was asking about red scotchbrite pads? They are about the same as the green ones they sell in stores, very rough.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-13-2012, 03:56 AM   #48
BigDan3131
BigDan3131's Avatar
I tried the CLR today and I wont use it again. It only seemed to work on the very light surface rust and I had to rub hard to make it work. I will post a picture of what I use tomorrow after work.
Old 08-16-2012, 02:11 AM   #49
BigDan3131
BigDan3131's Avatar
Okay, I had to find it. I use a 6" cup brush made of nylon filament like this:Dominion TNBC Nylon Cup Brush, Nylon Cup Brush... Dominion TNBC Nylon Cup Brush, Nylon Cup Brush... I currently am redoing someone else hack job right now and these work great for stripping layers of paint of if you take your time. They also take the light rust off faster than the messy clr.
Old 05-13-2013, 07:37 PM   #50
edub981
Has anyone done this with the CLR and green scrubby... and then clear coated? Curious if the rust came back under the clear coat... I wouldn't think it would come back as the clear coat would lock out the O2...
edub981 is offline   Reply With Quote
