02-23-2011, 11:43 AM | #26 | |
LSX addict
Re: Gears for a T56?
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] |
02-23-2011, 11:51 AM | #27 |
Charlie Daniels w/ a Tq Wrench
Yep, unless it was the even more powerful LS2
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
02-23-2011, 02:23 PM | #28 |
Rob that is looking good, could you grab me a measurement on your engine placement? Just something simple like from the radiator to the passenger side head or something to be consistant. I built my own mounts years ago and am looking at the placement of the shifter, I am afraid it will be too far back on mine, your inside photo shows the placement in relationship to the stiffener rib. Anyway when you have a chance if you could. I will be swaping mine out before long, i also have a 6.0 if necessary, i have been collecting for a while. These things do see to have a fair amount of torque even my little 5.3.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-23-2011, 02:49 PM | #29 |
I had 2 firebirds and a corvette all with LS1 powered T56 trannies. They all had stock 3.42 gears and I used 6th gear (.50 ratio) from about 45-50 on up. This was just cruising around and it worked fine.
I'd go with 4.10s for a good comprimise. |
02-23-2011, 06:28 PM | #30 | |
Guys thanks for all the good info and suggestions. Obviously everyone has different driving styles and preferences. Since the truck has 3.73s already, I'll probably add a posi and drive it for a while to see how I like it and then go from there.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-23-2011, 11:09 PM | #31 |
nope Rob that will give me a reference dimension. just wanted to see where my shifter would be, i think i may have to move it forward.
02-23-2011, 11:40 PM | #32 |
They make a kit that will move the shifter location to the forward access plate, but it's not cheap....
02-24-2011, 12:07 AM | #33 |
I moved my T56 shifter forward using the Keisler kit. The stock shifter comes up under the seat if you want to use the original bench. Here is a thread on the modification. It is a bear but mine works well in the end.
http://67-72chevytrucks.com/vboard/s...d.php?t=300892 TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
02-24-2011, 10:20 AM | #34 |
Thanks tr yes I had followed ur thread and have it saved. I may attempt it myself like u did. I sat my motor as far back as possible so yes I will have some interferance. my auto sure works good now. we will see on what I do.
02-24-2011, 04:33 PM | #35 |
And with 3.07s 349mph Bonneville anyone
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
03-01-2011, 01:13 PM | #36 |
Just thought I would chime in,
I had trouble with this decision also. For my LS2 I ended up going with 4:10's with a 29" tire, 4L65e (1rst:3.06, 2nd:1.63, 3rd:1.00 4rth:.070), 3200 stall I am now struggling with cam specs with this set-up. I would recommend determining that at the same time. I was after a real lumpy cam but the weight of the truck also becomes a factor. With that being said, how much does 300lbs make??
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
03-01-2011, 03:07 PM | #37 |
LSX addict
well with the t56 it wont matter really. the cam wont effect it like it does a auto, will affect drivability tho
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] Last edited by kSStamp0182; 03-01-2011 at 03:08 PM. |
03-01-2011, 10:12 PM | #38 | |
Here's some more pictures of the positioning...
11-14-2011, 07:54 AM | #39 |
Rob, how is this project coming along?
I am about to install a T-56 and was wandering how the gear situation worked out with this truck. That looks alot like Shifty's old truck. I know he sold it, but didnt know to who. If it is, I have the original steering wheel.....if you are interested. Last edited by dznucks; 11-14-2011 at 08:03 AM. |
11-14-2011, 01:17 PM | #40 | |
11-16-2011, 12:06 PM | #41 |
JRods Garage
Watching this as well...
Orange Julius-My dropmember'd, LS'd, SWB street machine... |
11-16-2011, 12:47 PM | #42 |
Just a car guy
The problem with running ,4.56 or 4.88 or 5.13s is you will rev so quick you will have to shift through the first 3 gears real quick.
These 6 speeds are great, but a comprimise has to be made. Most the guyson pro-touring.com that run these in there cars with a 28" tire run 3.73 or 4.10's and most will say 6th gear is not used much at all, but the the rear gear works well with the first 4 gears of the trans.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
11-16-2011, 07:23 PM | #43 | |
02-22-2013, 06:19 PM | #44 |
Here is a crazy question, I have read what everyone has thought find it all very interesting. Is there anyone running a old V8 or inline 6 with this trans? I have a thing for L6's and thought it might be cool to have a 67-72 Suburban with a 250 and a t56 and a 3.73 or 4.11 rear end. The reason I would like to go with this would be it would be a simple power train (at least at the dream stage) that would get decent fuel mileage for long trips. I don't expect to anything over 20 but one can hope. Another question I have is it true that you have to use a hydralic clutch?
I pity the fool with only 2 headlights! |
02-22-2013, 09:31 PM | #45 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-23-2013, 10:13 AM | #46 |
YES!!! That is the direction I want to go.
