Old 02-21-2011, 10:10 PM   #26
85/05Silverado
85/05Silverado's Avatar
Re: 6" front drop
Originally Posted by mooseknuckles View Post
get the spindles, and if you want to go lower, buy some bags, brackets, airline and a few fittings, run it off a schrader vale and your done. and bag the rear when you can afford it or whatever.
sorry to thread jack but what do you mean by "schrader valve" ? i wanna bag the front of my 85 also then do the rear when i can afford to
Hows it goin Eh!
1985 Chevrolet C10 Silverado SWB-395 Stroker 490hp,700R4 12 bolt 3:73 posi,inferno red crystal pearl coat with black ralleystripes,custom leather seats, carbon fiber gauges
2005 silverado 1500 ecsb, Z71, 33x12.5 dick cepek
http://www.cardomain.com/id/Kearney
Stephen
85/05Silverado is offline   Reply With Quote
Old 02-21-2011, 10:45 PM   #27
SBTork
Garage wrench
SBTork's Avatar
Re: 6" front drop
A schrader valve is like a tire's valve stem. It's just a less expensive alternative compared to buying an air management system. You can manually fill/deflate each bag with it.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-21-2011, 10:57 PM   #28
85/05Silverado
Re: 6" front drop
cool thanks alot
Hows it goin Eh!
Stephen
Old 02-22-2011, 10:35 AM   #29
Jonboy
Slots go on anything!
Re: 6" front drop
I think mine is about 6/8. It was Scot's DD, and will be mine when it comes back from Vintage Air. You have to pay attention to what's in the road, but I don't have a problem with it. The control arms are bent, but that was from all of the road construction that popped up by Scot's place in the last couple of years. I was figuring to have to raise it up when I first got the truck, but I don't think that is going to happen. I like the way it sits too much. My commute is about 30 miles each way. I drove the truck probably once a week to work before the engine/trans swap. Now that it is injected with an overdrive, that will help.
1974 Jimmy- 5.3/4L80e/NP241
