Old 04-11-2013, 02:45 PM   #26
semn49
Re: '01 crown vic front on '49?
Like this.
http://www.speedwaymotors.com/Speedw...Kit,42373.html
Seriously thought of getting this and bolting my parts to it. But I'm not sure Crown Vic parts are the same.
semn49 is offline   Reply With Quote
Old 04-11-2013, 06:22 PM   #27
khan1369
khan1369's Avatar
The lower control arm for the Crown Vic is not the same as a mustang II control arm. I have never seen a mustang II control arm anything like the 03 + crown vic lower control arm. So i highly doubt you will find a cross member with the right style mount for the crown vic arms. and judging by the looks, the lower control arm on the Crown Vic take the brunt of the work for the front suspension while the upper control arm is more of a guide than load bearing.
The Mustang II crossmember on Speedway does not include the lower control arm pivot tubes are not included, but are needed to mount mustang 2 style lower control arms. You may be able to modify it to mount the CV arms... it will take some fabbing skills.
In the end I personally think it will still cost more than fabbing your own crossmember based on the Crown Vic out of steel.
"Live, Love, Build cool s***"
Jesse Chapman, 2013
My Truck..
http://67-72chevytrucks.com/vboard/s...d.php?t=567219
khan1369 is offline   Reply With Quote
Old 04-11-2013, 06:35 PM   #28
khan1369
khan1369's Avatar
Jesse Chapman, 2013
My Truck..
Old 04-12-2013, 11:57 AM   #29
semn49
Well, it's all mounted under there now, all that's left is the steering, which I would have to figure out anyways. So (someday) I'll get the rest of the truck to the point where I can test it to see how bad or good it works.
Old 04-12-2013, 12:06 PM   #30
NONHOG
NONHOG's Avatar
Where's the "like" button?!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is online now   Reply With Quote
Old 04-12-2013, 05:15 PM   #31
khan1369
khan1369's Avatar
Awesome. got any pics? I wanna see how you did it.
Jesse Chapman, 2013
My Truck..
Old 04-13-2013, 09:58 AM   #32
semn49
Starts on page #1, post #16. As I said, the steering isn't done yet but the crossmember and suspension is Mostly installed.
Old 04-13-2013, 08:44 PM   #33
khan1369
khan1369's Avatar
aah. So you stuck with the cut down CV cross-member. Right on. I thought you had gone with the mustang II cross-member. I am looking forward to seeing how you conquer the steering. Have you looked into the ford escort rack? I read somewhere that someone was using this because it was shorter. I wish I could find the post...
Jesse Chapman, 2013
My Truck..
Old 04-14-2013, 06:25 PM   #34
semn49
Thanks for the tip on the escort rack. Whatever I use it will have to be from something that steers from in front of the axle, not sure how an escort does.
Old 05-29-2013, 11:57 AM   #35
Greg55_99
Might be of interest:
http://www.jalopyjournal.com/forum/s...d.php?t=683419
The steering rack was cut as well as the crossmember. Gotta be brave I guess.
Greg
Greg55_99 is offline   Reply With Quote
Old 05-30-2013, 01:19 PM   #36
semn49
Thanks for the link. It sure helps to look at how others tackle things in different ways.
