02-23-2011, 05:46 PM | #26 | ||
Re: How can I fix this?
This is what I was leading up to and will try this tonite and post any pictures of any movement to see if it works out. Wish one of you could come over and do it for me. I'll buy the beer. |
02-23-2011, 06:08 PM | #27 |
Well first off, the gap at the back is hard to fix because when you move the fender in, the hood moves the same amount because the hood hinge moves with it. So you can loosen the bolts that mount the hinge to the bottom of the hood, pull the arm of the hinge towards the passenger side fender, then tighten while holding in position. (basically pulling the bolt shank to the side of bolt hole slot in hinge) Or if desperate, put shims behind hinge on fender.You really should have the cowl panel installed, and lined up with hood.
The front gap is easier. That triangle brace at the front has slots, just loosen the bolts that go to core support, you should have some adjustment there also. Mount the grill shell, if you don't the spacing at the bottom may be off, which also affects the gap along the top of fender. There is a bolt that bolts the fender to the core support thats down lower, behind where the battery mounts. You can loosen that bolt, and move the bottom front of the fender, that will pinch the gap closer togather, or further apart. (extension in front of wheel well) The gap at the very front tip of the fender\hood kinda flares out a little, good luck on that. (I welded in a little patch for that) I know, clear as mud Watch out moving the radiator core support, it will change the gaps along between the doors and fenders. Last edited by biggestjohn; 02-23-2011 at 06:21 PM. Reason: more |
02-24-2011, 04:48 PM | #28 |
Curious, What all is suppose to be loose or taken off the core support before moving it over? Everything?
02-26-2011, 11:01 AM | #29 |
Just loosen the bolts on either side of the radiator that go thru the frame and mounts.this will move the whole front over as one piece.Wont take much,your just lookin for a fraction of an inch, basicly half the distance of the gap you have to close at hood.If your support hasnt been moved lately you may have to use a porta power to move it initially.Make sure your doors are where they need to be,everything starts with the doors,cowl panel,hood,then once all gaps are right on those align the core support and fenders to them.sounds hard but once you see the cause and effect of positioning panels it gets easier to understand.then its just trial and error.Ive been doin this for 20 yrs and i get stumped occasionally.Good luck
02-27-2011, 04:07 PM | #30 |
Well nothing,
Ive moved fenders, cowl, core supprt, hood, hinges. Just about to pay someone to come down and allign the dang thing. anyone wana make a quick $50-$75?? Ill even supply the beer. |
02-28-2011, 01:38 PM | #31 |
Well nothing,
Ive moved fenders, cowl, core supprt, hood, hinges. Just about to pay someone to come down and allign the dang thing. anyone wana make a quick $50-$75?? Ill even supply the beer. After the beer you wont have to align anything, It will all look nice and straight. |
02-28-2011, 04:20 PM | #32 | |
I ended up calling my old man and hes gona come try it out for me. If he cant do it then Im going to take it down to a buddy of mine who own a body shop in Chico. (were not buddies enough that I wont have to pay him) but at least it will get me to the strip point for the body work. |
02-28-2011, 05:24 PM | #33 |
i dont know if u have the inner fenders in or not it makes things more easy without imo i loosley bolt fenders to core suport w/core suport loose also uwant to get good door gaps first then move foward some times u must shim core support /enlarge some holes your frame could be tweeked also keep at it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
