Old 02-13-2012, 05:48 PM   #26
gopokes
gopokes's Avatar
Re: Serial data wire?
Originally Posted by imsuchaman55 View Post
The more I look around and read about it, the more I think its a voltage issue. When I turn my key on, the volt meter goes up, but none of the lights on the left side of the cluster light up, and the odometer window doesnt light up. I was getting the power from the fuel gauge feed, and it must not have been enough to power everything. Im going to wire it up direct and see how it works.
For the fuel gauge, we took the internals of the original 68 cluster, removed the needle, and epoxied it into the camaro cluster, then put the camaro needle on. I had to run 3 wires out of the side of the cluster for the fuel gauge. Ground, fuel gauge feed, and signal wire. But it works good and much easier than trying to make the stock fuel gauge work.
We haven't done the final wiring yet. That was just when we wired it up for a test, so the voltage issue could be your problem. I'm hoping I don't have trouble with the fuel gauge, I'm using the fuel tank and sender from a newer Camaro, so it should wire straight up. Hopefully!
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 02-14-2012, 06:35 PM   #27
imsuchaman55
imsuchaman55's Avatar
Is there any way I could get a pic of what wires you spliced into? If it was just the colors that would work, since I have the pinouts with the colors. I would appreciate it
imsuchaman55 is offline   Reply With Quote
Old 02-14-2012, 07:14 PM   #28
gopokes
gopokes's Avatar
No problem, I should be able to get a pic tonight. Might be a little later though because of valentines day and what not.
Old 02-14-2012, 09:41 PM   #29
gopokes
gopokes's Avatar
Ok, so I wasn't thinking about the fact that the guy that did my harness didn't just use the factory wires. All of the 12 volt wires coming out are red, switched or not. The OBDII port wire is a solid green wire, that and the oil pressure line are the only two I have hooked up other than the all time 12 volt, keyed 12 volt, and grounds. I have only tried this when I had everything running directly off the battery, not through a fuse block at all. I can take a pic of it and get it too you later, but it seems like this isn't much help to you.
Old 02-14-2012, 10:03 PM   #30
gopokes
gopokes's Avatar
Found this document on my computer that we used when we were hooking this up, the red font are the only things we used. I think that B9 might be your issue.
Instrument Panel Connector Pins
Pin color use
A1-2-not used
A3---pink------fused ignition feed (Hot on START and RUN)
A4---not used
A5---tan/wht--brake warning indicator lamp input
A6-7-not used
A8---brwn/wht-SES light
A9---not used
A10--orn-------fused battery feed
A11--not used
A12--lt blu------left turn input
A13--ppl/wht---seat belt indicator
A14-16-not used
A17--lt grn------high beam indicator
B1---brn--------park lamp feed
B2---not used
B3---gry--------security indicator input
B4---not used
B5---ppl/wht----fused ignition feed (Hot on START only)
B6---gry--------Class 2 Serial Data ***********
B7---orn/blk-----rear compartment lid ajar indicator
B8---dk grn/wht--vehicle speed signal
B9---gry---------instrument cluster lamp feed
B10--dk blu------right turn indicator input
B11--blk----ground
B12-13--not used
B14--tan---------oil pressure gauge input
B15--blk wht------ground
B16-17- not used
Old 02-15-2012, 11:55 AM   #31
imsuchaman55
Pin color use
A1-2-not used
A4---not used
A6-7-not used
A9---not used
A11--not used
A14-16-not used
B2---not used
B4---not used
B11--blk----ground
B12-13--not used
B16-17- not used
Yes I think that could be the problem too. The pinout I have is a little different than this one. Mine says A13 is the instrument panel lamp control, and I had both B9 and A13 wired together to the dimmer switch, but noticed the seat belt light is always on. Maybe the pinout chart I have is for a different car. Did you connect B9 to 12v or to the dimmer switch?
Thanks for going back and helping me with this, I really appreciate it.
Old 02-15-2012, 01:02 PM   #32
gopokes
gopokes's Avatar
I haven't done the final wiring yet, but I had it hooked to 12v key on for the test. I guess it would need to go through the dimmer switch as well.
