Old 03-04-2011, 08:43 AM   #26
BigBlocksRule
Re: Pro street
Frank, shoot and post a pic of that truck from the rear, I'd like to see how those meats look from behind.
I'm toying with the idea of switching to 4-link, adding dually fenders, having dually wheels widened to 9" and running a pair of 295's on each side. I think my 565 should be in the neighborhood of 800hp N/A, building it to take 400hp shot of spray.
BigBlocksRule is offline   Reply With Quote
Old 03-04-2011, 11:00 AM   #27
CoggedBelt75
CoggedBelt75's Avatar
Re: Pro street
Here's a few of mine. Coil-overs instead of leafs, 4 link, narrowed rear-end (44" end to end), 15x14 Convo-Pro wheels with 4 1/2" backspace. With the 31x18.5 Hoosier radials (18" sectional width, 14.5" tread) there is 2 3/4" between tire and fender lip. The Hoosier 32x14 slicks (19.9 sectional width, 16.3" tread) there is just shy of 1" between tire and fender lip.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 03-04-2011, 09:06 PM   #28
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Pro street
Joe,
For some reason every time I see a pic of your rig, I get a bad case of envy fever !!!
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-05-2011, 07:48 PM   #29
BigBlocksRule
Re: Pro street
Thanks for the pics, Joe. If you don't mind, I'll ping you when I get closer to my 4-link project.
I never get tired of looking at anything with steamrollers!
Old 03-05-2011, 08:23 PM   #30
Restrorob
Restrorob's Avatar
Re: Pro street
Originally Posted by BigBlocksRule View Post
You really need a big block if you want to pull the pro street thing off.
BigBlock,
You know Joe's steamrollers are connected to a small block, Did he fail at pull'n off the pro street thing ?
I'm just try'n to figure out where your coming from, I've seen way too many small blocks lite steamrollers up !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-05-2011, 10:53 PM   #31
f.monroe
f.monroe's Avatar
Re: Pro street
If I can get more pics from the rear I will post them . I only have one other but its from the side .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 03-05-2011, 11:18 PM   #32
dbmx66
Re: Pro street
Ain't no N/A smallblock that'll shake the fenders like a 540 or bigger. Add spray or boost to a smallblock and it'll keep up....
right up 'till the mountain motor gets the same...then the real thunder will ring from the pipes!
"Hold her head, Luke, she smells alfalfa!"
all i have to say is, i think its great wen our little n/a 383 super gas tube chassis firebird goes up against a 600 plus ci and gets the win light, people come up in the pits and ask what motor we have in it, and the look on their faces are priceless when you say an n/a small block
dbmx66 is offline   Reply With Quote
Old 03-06-2011, 08:34 AM   #33
BigBlocksRule
Re: Pro street
Whoa, guys, ain't trying to start a big block vs small block thing...I just prefer big blocks for big torque. There's a reason that Top Fuel, Pro Stock, etc. all run 500 cubic inch big blocks...'cause the rules say they can't run bigger! The initial remark about needing a big block wasn't necessarily directed at the truck's owner but at all the guys "back in the day" that ran big honkin' tires with an anemic crate 350 under the hood. That ain't ProStreet to me, it's all show and no go.
And my money says more than one big block has got the win light against that 383...there's a lot more to winning than having the most powerful engine, anybody who's raced very much knows that as I'm certain that you do. Running super gas ain't no picnic, y'all have spent countless hours dialing that car in, racing has to be a passion at that level, nothing like grudge matches at the test-n-tune. I'm guessing you're running an index which would mean those mountain motors are detuned or running a throttle stop to keep 'em in the bracket. A good tuner is as valuable as a good engine builder at that level, IMHO.
Nowadays, the LSX engine family is making it's mark and big block or early gen small block, both are learning that these newfangled LS powerplants are capable of making some insane numbers. Talk about pi$$ing a few folks off, many Mustangs are racing with LS engines between the frame rails, it sho 'nuff gets the Ford guys' feathers ruffled when they see what's making their beloved Rustains fast
Old 03-06-2011, 10:28 AM   #34
SeanPaintsFlames
SeanPaintsFlames's Avatar
Re: Pro street
Cougar-
If I were you I'd just resell the parts you got a deal on (for more) and spend it on something else. You may have gotten a deal this time, but what about when your son needs new tires the next time? Those fatties aren't cheap.
Pics of the 68? I've got one too. Are you on MC.net?
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 03-06-2011, 11:33 PM   #35
68cougar
Re: Pro street
yea i know they aint cheap but its for my boy so its all good. Yes im on mc.net.....sons project then daughter then ill redo the cougar again, trans am racing style i think
68cougar is offline   Reply With Quote
Old 03-07-2011, 10:26 PM   #36
SeanPaintsFlames
Re: Pro street
Nice!
Old 03-14-2011, 09:29 PM   #37
85_prairieboy
85_prairieboy's Avatar
Re: Pro street
I did the leaf spring trick on mine. The width of the frame rails is ~34" so make sure your tires are going to have enough clearance when they are mounted to the rear end. I'll warn you that you will be sick of rivets by the time you are done lol
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 03-14-2011, 10:01 PM   #38
Restrorob
Restrorob's Avatar
Re: Pro street
So, All you did is swap the leafs inside the frame ?
Also, What's the backspacing and total width of your rims and tire brand and size ?
Sorry for all the questions, Your rig looks SICK !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-14-2011, 10:21 PM   #39
85_prairieboy
Re: Pro street
Thanks Rob. Yeah I took the spring from the right side and mounted it on the inside of the left frame rail and vice versa. I had to box the rails where the mounts go. The wheels are 15x14. I'll have to look up the backspacing. The wheels were custom built for another vehicle so I didn't get to choose the backspacing. I narrowed the rear end enough for them to fit my truck. The tires are 32x14 Hoosier slicks. They are just an old set I used for mockup.
1980 Z28 Camaro
Old 03-14-2011, 10:35 PM   #40
68cougar
Re: Pro street
85_prairieboy, truck looks great. just waiting for some time to do my sons.
Old 03-14-2011, 11:22 PM   #41
gas-n-rods
gas-n-rods's Avatar
Re: Pro street
68cougar, my truck has a morrison frame clip and narrowed 9'' 4 link. If you ever make it up north look me up I am in Aztec, NM
1984 Chevy C10 Pro Street
1985 Chevy C10 long bed - SOLD
1938 Chevy Tudor
1999 Harley Softail
gas-n-rods is offline   Reply With Quote
Old 03-17-2011, 12:23 AM   #42
68cougar
Re: Pro street
gas-n-rods if i ever get up that way i definately will. If you have any pics i would love to see them.
Old 03-17-2011, 09:19 PM   #43
gas-n-rods
gas-n-rods's Avatar
Re: Pro street
Heres some pics for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=452245
1938 Chevy Tudor
1999 Harley Softail
Old 06-08-2012, 09:45 PM   #44
GMC YA
Re: Pro street
Nice truck. Can you shoot a pix close up of your setup underneath between the tires
I would love to see how the rear is set up dragntransport@yahoo.com maybe email me if you could thanks
GMC YA is offline   Reply With Quote
Old 06-09-2012, 12:23 AM   #45
badpontiacs
badpontiacs's Avatar
Re: Pro street
badpontiacs is offline   Reply With Quote
Old 06-09-2012, 07:42 PM   #46
gas-n-rods
gas-n-rods's Avatar
Re: Pro street
9" Ford from Strange, 411 Gears with ARB Air Locker, Art Morrison rear Frame Clip, 4 Link, Air Bags
1938 Chevy Tudor
1999 Harley Softail
Old 06-10-2012, 07:07 AM   #47
D13
D13's Avatar
Re: Pro street
Badpontics' middle picture is simply the most awesome rear shot of a GMC ever. That right there is every square body truck lovin' drag racers' harcore porn centerfold.
Curse you, now I got to find short step bed and learn how to MIG.
Of course, with a 250 or a 6.2 diesel, mine will be a little slower.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-10-2012, 08:11 AM   #48
Hertzdaddy
Re: Pro street
I've been wondering about this spring swap idea too. Another idea would be to get some spring mount tabs to mount the front of the leaf spring under the frame rail (ala S10 style) and then hang the shackles out back like the rear of the front spring on the 4x4's. Or maybe use the slider style of spring mount from AFCO/Speedway Motors for the rear. Anyone know how those would ride on the street?
Hertzdaddy is offline   Reply With Quote
Old 06-10-2012, 02:31 PM   #49
bustedknuckles
bustedknuckles's Avatar
Re: Pro street
To "tub" mine originally I moved the leafs inside the frame. Didn't like the ride or traction issues, so instead of caltracs and better shocks and possibly a sway bar I went with a 4 link and coil overs. Here's a couple pics. 15x14 welds on 31x16 mt sr radials.
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline   Reply With Quote
Old 06-10-2012, 08:02 PM   #50
gas-n-rods
gas-n-rods's Avatar
Re: Pro street
good Job. 4 Link is by far the better way
1938 Chevy Tudor
1999 Harley Softail
