#26 |
Re: Steering Wheel Options - 72 C10
I used a 15" grant,
68 ![]() My other ride ,,, 07 Streetglide.. |
#27 | |
1969 C-10 short step 1981 CJ7 2017 Ram 2500 Laramie 4X4 1939 Cadillac LaSalle sedan 1950 Allis Chalmers B 1998 Bullet 21 XD 300 Merc/water hot rod |
#28 | |
www.tomthetruck.blogspot.com <-- Aka build thread. |
#29 |
RAT1968 '68 Cab/'71 Parts
I bought this Italian half-wrap (about 13.7" and less than an inch deep) on EBay for $50 + $9 shipping from a guy in Kansas. It's a marine wheel. I mfg'd a horn set up using the stock left-over stuff, and bought a Grant hub adapter. Then I drilled under the horn ring on the wheel to match the pattern on the hub. No big deal. If I didn't have to do the R and D, the whole thing wold have cost (less the wheel), about forty bucks.
I'll post pics on the tilt column as soon as it goes on for "the count". Right now, I have nothing on there so I can do my damage (work) on the interior. But I can tell you, for an upscale final look, you can't beat the price. Except that one that someone got for $15 at the wrecking yard.....Nice.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 03-09-2011 at 01:36 PM. |
#30 | |
#31 |
#32 |
Purchased this off ebay.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#33 |
Mine, stained the wood black.
Posted via Mobile Device |
#34 |
Here's the one in post #29 installed.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#35 |
![]() Join Date: Apr 2008
#36 |
(007) aka Houdini
![]() Join Date: Mar 2010
I got the modern wheel on my like Bigdogboxers posted in the pic. I'm toying with the idea of switching over to a wood wheel and I like the chevelle/etc wheel too ....blasted hard choice to decide......
Live life one day at a time! |
#37 | |
Shoot the seller a note and let them know you want the stainless steel spokes. You also want the one that fits the 67-68 Camaro. The horn button is the same as a factory button. I just added a GMC wheel center, which matches the finish on the horn button pretty well. Of course if your driving a Chevy, no need to do this. http://www.ebay.com/itm/1-GMC-Wheel-...sories&vxp=mtr ![]()
#38 |
Thanks Z10!
#39 |
#40 |
this is a long running thread - hope it's ok to revist.
I'd like to ask a question regarding the size. What is a pretty common size on the swaps? I'm not a big guy - 5'7", but I have a bit of a gut. I was 330 lbs and lost 100 so the stock steering wheel hits me right where all my weight loss fat is ![]() I had a 13.5" steering wheel on my s-10 mini truck and I liked it, but I think it is a little small for my 70. I'm thinking maybe a 14.5" or a 15". I know no one can really give me a 100% correct answer since it is a prefernence issue, as well as my comfort, but I'm just kinda curious as to what sizes seem to be the most common because they offer comfort with good turning radius, etc. |
#41 |
[/QUOTE] I know no one can really give me a 100% correct answer since it is a prefernence issue, as well as my comfort, but I'm just
kinda curious as to what sizes seem to be the most common because they offer comfort with good turning radius, etc.[/QUOTE] Okay. You are correct. Also, factor in "tilt"? Or "power steering"? Seats? Where's your gas tank? Here's my story: When I started this build three and a half years ago I was fatter. I'm 5'8" and still way too fat. But much smaller in the gut now than before. But still. ![]() When I started, I had a non-tilt column, bench seat, and power steering. Gas tank in the cab. So, I got this small wheel. It's 13.75", outside diameter. During the build, I came up with buckets and the tilt column. I guess most folks don't like the design factor (non-stock) aspect of the smaller wheel. But I've always liked the look and feel of them. And, with power steering, the leverage benefit of the larger wheel is moot. So, I'm very happy with this steering wheel. Leather and wood. A good combo, I think. Here are a couple of shots. Funny, when I backed in this morning I didn't turn the wheels straight. But you get the point...it's about size, right?
#42 |
kinda curious as to what sizes seem to be the most common because they offer comfort with good turning radius, etc.[/QUOTE] Okay. You are correct. Also, factor in "tilt"? Or "power steering"? Seats? Where's your gas tank? Here's my story: When I started this build three and a half years ago I was fatter. I'm 5'8" and still way too fat. But much smaller in the gut now than before. But still. ![]() When I started, I had a non-tilt column, bench seat, and power steering. Gas tank in the cab. So, I got this small wheel. It's 13.75", outside diameter. During the build, I came up with buckets and the tilt column. I guess most folks don't like the design factor (non-stock) aspect of the smaller wheel. But I've always liked the look and feel of them. And, with power steering, the leverage benefit of the larger wheel is moot. So, I'm very happy with this steering wheel. Leather and wood. A good combo, I think. Here are a couple of shots. Funny, when I backed in this morning I didn't turn the wheels straight. But you get the point...it's about size, right?[/QUOTE] That u for this...it's a great help. I do have power steering, but not tilt. Factory bench seat for now as well. I did read that I can remove some tabs to push the column in some, s I might look into that. I think the 13.5 or 14 will probably work just fine then Posted via Mobile Device |
#43 |
#44 |
nobody rolls a 17 or 18 inch peterbuilt with the suicide knob? Thats where I'm heading. Havent found a wheel I like yet though.
#45 | |
Thanks. Posted via Mobile Device |
#46 |
@SC C-10 Thanks for the pic! I was about to shell out big bucks for a Lacarra steering wheel and had never thought about 90's model cars. I just picked up a Cavalier steering wheel from a local salvage for $25 and it looks a lot better than most aftermarket wheel imo.
#47 |
Old member
Same one for any Chevy wheel. They fit most GM wheels to the column.
Here is my new 67 SS wheel I installed. I like it a lot better. I did the leather wrap myself. ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#48 |
Still plays with trucks
I know really old thread but I had info that could help people out with a great factory steering wheel so I thought I would share.
This is the NK1 option code steering wheel that was standard on the 1969 through 1975 Corvette and optional on the 1969 Camaro, 1970 Chevelle, Monte Carlo & full-size passenger cars and optional on the 1971 through 1975 Buick GS. They are incorrectly referred to as the Comfort Grip steering wheel when Chevy actually called them the Cushioned Rim steering wheel. The nickname stuck and you will have a tough time finding them referred to as anything but Comfort Grip. The Corvette wheel and some of the others were 15" outside diameter and are commonly referred to as the small Comfort Grip steering wheel but there is a 16" diameter version as well that is the large Comfort Grip wheel. Both sizes are commonly available as new reproductions for a pretty good price compared to many of the other options out there. I eventually put them on everything I build.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#49 | |
Photo of my current wheel which is similar.
#50 |
![]() Join Date: Dec 2018
Hello,
Just bought '72 GMC. Can u tell me what year of Corvette wheel you used and what adapter kit did u have to get ? Been looking at Grant but like the Corvette wheel you used. |
