#26 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Drop Spindles and Tie Rod Length, 69 C10
I glad things worked out. I thought maybe Edelbrock had changed their design.
#27 |
#28 |
Any update on tie rod lengths? I installed Western drop spindles on my '71, I had to change to the 73+ outer tie rod ends. I went to get the truck aligned today and while trying to adjust the toe the passenger side inner and outer rods are actually touching each other and I don't have enough toe in yet. Are there shorter 73+ outers? Shorter 71-72 inners?
Thanks guys |
#29 |
Got any pics?
#30 |
I don't. Looking through the split in the stock adjuster you can see the threaded ends of the inner/outer rods touching.
Keith, is there something I can take a picture of to better illustrate the situation? I'm not sure why the driver's side isn't an issue. I am having wheel rubbing issues after the spindle install. A bent frame wouldn't be the issue, right? Steering would shift with the frame? http://67-72chevytrucks.com/vboard/s...d.php?t=563913 |
#31 |
Wheel rubbing may be due to the wrong backspace wheels or the need to trim the lower a-arms.
It's common with 15" wheels with more than 3.5" of backspace. The earlier tie rod sleeves are longer. But the 71-72 and 73-87 tie rod sleeves are the same length. I assume your spindles are 73-87 spindles?
#32 |
Well it's odd that only the driver's side is rubbing.
It was my assumption that they were 71-72 spindles. I clarified with the gentleman I bought them from on the board that he used the 73+ outers and upper ball joints. My original '71 rotor fit the spindle. Perhaps early CPP spindles required the change? At any rate, I need to find a solution to my misalignment. The combo is 73+ outer tie rods and upper ball joints, early CPP spindles, then the old '71 rotors, inner tie rods, lower ball joints and center link. I can't objectively confirm it but I believe the alignment was wrong prior to the spindle change. The P/S toe in was basically maxed out on the previous setup, much unlike the D/S. |
#33 | |
CPP still sells this stupid kit that converts to 73-87 spindles. That's what you have. 73-87 HD spindles. Your 71 rotors will bolt right on these. I have done this exact swap with no issues.
#34 |
Exactly what Lolife said is 100% Valid!
