Old 03-14-2011, 08:37 AM   #26
entourageguy
Yellow truck club
entourageguy's Avatar
Re: need help from the suspension experts
Yes I noticed that as well. Considering there is not much weight on it in the pictures and the shackle is already pointing rearward. I wonder what it's position will be with the weight of the box on it.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-14-2011, 03:22 PM   #27
weldvair@embarqmail.
With the wt on the spring the shackle is moved to the rear at a 30 degree angle.
Don
weldvair@embarqmail. is offline   Reply With Quote
Old 03-14-2011, 04:55 PM   #28
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Don
Don that is definately part of the problem if not the problem.
If you hit a good hard bump your shackle can lay over almost flat.
At rest with no weight in the bed the shackle should lean away from the cab at a 5-10 degree angle.
I did the math, assuming you have a 50" spring that has a arch that is 4" deep with a 30 degree shackle, it will take 3" of suspension up travel to make the shackle lay at a 62 degree angle.
That is 28 degrees away from flat, and it will seriously bind the spring because the spring will have to pull the shackle back forward in a direction that it does not have the mechancial advantage. At that angle the shackle only has to travel .46" backwards to go full horizontal.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
