Old 03-15-2011, 11:14 PM   #26
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: woodgrain dash bezel
Originally Posted by ETsC10 View Post
Trevor, that would be cool.
I've been thinking on this thread since yesterday
and found samples of 3M's Di-Noc Wood Grain Series
lettering vinyls.
I wonder if this might make an
affordable alternative for daily drivers?
That's what CSM uses. #254. It really isn't affordable. It's pretty expensive. I am working on a correct grain woodgrain. I actually have the correct grain in Vintage OEM woodgrain vinyl. The color is a little off, but the pattern matches the OEM interior pieces. I have covered a glovebox door with it and will try to snap a pic of it if I have time after work tomorrow. I have bought several old stocks of woodgrain, and only 2 rolls were the correct grain, but very very very hard to find.
My woodgrain dashes will be like the originals. The original were a really thin piece of plastic with the woodgrain vinyl laid on it. I have verified this with several original production line dash bezels. The main thing I don't like about the repops and CSM's (not calling them out, as they do good work) is that the grain isn't at all like OEM pieces. It's just a woodgrain vinyl slapped on in any fashion. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-15-2011, 11:20 PM   #27
71blksuper4x4
SWB 4x4 Collector
The hardest thing to make for me, are the thin plastic dash bezel backing plates. OEM dash bezels are different from repops in gauge hole sizes, and there are different styles of aftermarket bezels. Every one that I make, I have to make by hand to fit it to the actual bezel it's going on.
Also, to answer the OP's question, the original Cheyenne Super bezels did have grain on them as well. That's the reason for the thin plastic backing. Something to keep the woodgrain from peeling from the uneven surface, and it is then contact cemented to the dash bezel. Trevor
TREVOR
Old 03-15-2011, 11:27 PM   #28
71blksuper4x4
SWB 4x4 Collector
This was just a set of old woodgrain panels I had that I refinished much like CSM's. Notice the woodgrain isn't like original, as I was just trying to get the process down before working with my good stock, plus, I wanted to see what woodgrain looks like on the hard to find 72 Red OEM panels. Trevor
TREVOR
Old 03-15-2011, 11:33 PM   #29
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Looks pretty good to me!
Zoomin is offline   Reply With Quote
Old 03-15-2011, 11:44 PM   #30
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Wow Trevor! That's great!
And, yes, high quality vinyl is getting pricey.
I had no idea these were laminated prior to
application.
Great Job!!
ETsC10 is offline   Reply With Quote
Old 03-16-2011, 02:09 AM   #31
leddzepp
Moderator
leddzepp's Avatar
Trevor that looks awesome!
As you point out however the woodgrain is different from original...I have gotten over it and am making sure all my pieces just match. I believe I have found a way to get the repop sticker to stick...but as you stated the problem is they do NOT fit the aftermarket bezels properly. Repo part + repo part = no fit I had no problem getting the sticker to line up properly on my OEM bezel....but then again, the chrome on my OEM bezel sucks, so we are back to square one.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-16-2011, 08:21 AM   #32
71blksuper4x4
SWB 4x4 Collector
Yeah, Scott that is some of my woodgrain that doesn't match. I'll try to get pics of the good stuff later today. Trevor
TREVOR
Old 03-16-2011, 11:52 AM   #33
1972K20
1972K20's Avatar
As you point out however the woodgrain is different from original...I have gotten over it and am making sure all my pieces just match. I believe I have found a way to get the repop sticker to stick...but as you stated the problem is they do NOT fit the aftermarket bezels properly. Repo part + repo part = no fit I had no problem getting the sticker to line up properly on my OEM bezel....but then again,the chrome on my OEM bezel sucks, so we are back to square one.
Is there a way to restore the chrome on an old bezel?
1972K20 is offline   Reply With Quote
Old 03-16-2011, 12:33 PM   #34
sameyrasmea72
sameyrasmea72's Avatar
You can have them re-chromed. That is what I did. I took a NOS GM woodgrain (painted silver) and removed the wood grain and then had the bezel chromed. Then you can put the woodgrain on the bezel it came off of and it will fit.
Like Trevor said, You can use The GM wood grain but it will not fit on a aftermarket bezel. Not only that, GM used atleast 2 different bezels too.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 03-26-2011, 06:24 PM   #35
VA72C10
VA72C10
VA72C10's Avatar
The picture of the dash above your posts is the correct woodgrain.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
