Old 03-15-2011, 11:55 AM   #26
slimneverdies
slimneverdies's Avatar
Re: Impressed with my truck's mileage.
Originally Posted by Clyde65 View Post
If it were me, I would take a week vacation, call a buddy ( mechanical one) and dive knee deep into that 5.3 swap! if you have your motor, your trans, your harness ( custom) and your PCM, you wont need much more, oh and an 87 FI tank. you should be easily done in a week. youll be glad you did!
I think this is why I haven't move forward yet..... I only have the engine and trans. All the wiring and computer stuff is what's making me second guess this. Then there's getting the dashboard to work.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 03-15-2011, 07:45 PM   #27
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I just averaged actually recoreded 15000+ miles on my ZZ4. I've documented the miles since breaking in the ZZ4 on a 1000 mile trip. Average total with city, highway and lead foot = 16.5 MPG. Lowest at 11 MPG, yea really lead foot. Highest 25 MPG, wow great back wind lower speed! Average now is 13.5-15 if I keep my foot out of in the city. 18.5 MPG on straight highway speeds of 70 MPH. Not bad for a square body. The difference is torque. The sweet spot for a 305 is ~2000-2200 RPMs at highway speeds. Keep it there and you'll do great. Keep city RPMs below 2300.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-16-2011, 11:01 AM   #28
NCD1966
NCD1966's Avatar
I've gotten 15 mpg city with my bone stock "84 sliverado. 305 engine with th350 lockup convertor and 3.08 gears. I guess I'll find out what it gets on highway during cruising the coast
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 03-16-2011, 11:13 AM   #29
blackbeaSSt
is my q-jet the reason im getting 9-10? or is there anything else i need to be looking for?
blackbeaSSt is offline   Reply With Quote
Old 03-16-2011, 11:41 AM   #30
NCD1966
NCD1966's Avatar
hey you guys with bad fuel mileage with a q-jet and a 305.
my 84 had the same problem for a while getting bad gas mileage. It ended up being the vacuum lines were dry rotted and they just disappeared. The truck still ran great but just got bad fuel mileage. We ended up replaceing a few lines and pluged the rest.
It solved the bad fuel mileage problem.
Just an idea, you guys may have the same problem.
Old 03-16-2011, 01:10 PM   #31
Goldfinger
Goldfinger's Avatar
I dumped the q-jet on my 305/700r4 for an edelbrock and now im getting low to mid 20's. I have changed my driving style alot. Easy swap except the egr gets in the way. you just have to take the spacer and fill it with jb weld bake at 400 then install with gasket sealent.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 03-16-2011, 01:39 PM   #32
blackbeaSSt
ncd and gold, thanks for the advice. i'll have my mechanic check it out tomorrow when he has the truck anyway!
Old 03-16-2011, 06:16 PM   #33
68longhorn
68longhorn's Avatar
I still run the Q jet and get good mileage
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 03-17-2011, 07:39 AM   #34
Goldfinger
Goldfinger's Avatar
Well mine had seen better days and after 25 years and 4 rebuilds it was toast.
Old 03-18-2011, 11:01 PM   #35
chevymotocross
chevymotocross's Avatar
Nice video and explanation of this guy's hydrogen setup on his 87' GMC. Never heard of this conversion, don't know how much it costs, but I will definitely be researching. His initial mileage numbers before the hydrogen install are low, so I'm not sure if he has a 700r4, and what gears, but his new mileage numbers are impressive for highway.
Anyone have any info on this system? Seems like with that much water coming out of the exhaust pipes, I might need to invest in stainless. Also, not sure if turbo style mufflers with packing would be ruined with that much water.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 03-18-2011, 11:41 PM   #36
James McClure
One shot, one kill.
Just watched the video and shot it full of holes. First off, he started it cold, there will always be water on cold start. Any combustion process has some water as a byproduct. Next he is using a simple process whereby you break water down into oxygen and hydrogen by electrolosis. The amount of hydrogen & oxygen produced is small and the speed of production is very slow. You would need 50,000 or 60,000 cubic feet a minute to make any difference. A cubic foot of gas is 288 cubic inches. 1 revolution of the eng is 350 cubic inches. With that info in hand, at an idle of 650RPM you would be processing 187,200 cubic feet of a gas for every minute of operation. Think about it for a minute. In this day and age when the car companies are looking for every advantage to boost fuel economy and in turn sales, don't you think they would be all over this like white on rice? Hydrogen production is expensive because it uses lots of electricity. In a vehicle, where does that come from? The alternator. What runs that, the engine. Which in turn gets it's energy from it's fuel. What the writer in the article is suggesting is a perpetual motion machine which defies all the laws of physics. Don't waste your money. Tune the eng, go thru the carb and lean it out, drive with a soft right foot. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
