Old 03-18-2011, 01:48 PM   #26
bruceman1968
bruceman1968's Avatar
Re: Where do you find th paint code on a 71?
Yes, Under or behind the seat. Between the springs and foam. Some guys have found them under the carpet or behind the tank, you never know. Most are long gone..
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-18-2011, 01:51 PM   #27
original-71
///Relaxed Atmosphere
original-71's Avatar
Originally Posted by bruceman1968 View Post
Build sheet if you have one.
no i wish i knew everything about this truck like were it came from and such. all i know is the guy that built it, builds one or two a year and i did find the painter.i can tell in some spots of the truck it is the same color as the original however the interior is not the original color like the seats and sunvisors but i like the way it blends with the truck is there a way to do a trace with the vin?
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 03-18-2011, 03:10 PM   #28
bruceman1968
[QUOTE=original-71;4561289 is there a way to do a trace with the vin?[/QUOTE]
Not with the VIN. The vin will not show options. The vin will show what assembly plant it was built at.
Also you might have a protecto plate with the owner protection plan. Have you found any paper work like that in your truck?
Old 03-18-2011, 11:58 PM   #29
clos69
Its Topless Season!!!!
clos69's Avatar
Originally Posted by no moa View Post
How can you tell?
YG8 code on your spid is the special promotion for Highlanders.
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 01-18-2017, 07:38 PM   #30
68Cervd
I know this thread has not been updated in a long while but why is it that almost every 71 I have seen is blue and white (even mine)
68Cervd is offline   Reply With Quote
Old 01-18-2017, 07:47 PM   #31
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by original-71 View Post
since i bought mine restored already but cheated of the spid because it was removed,how else can you tell what equipment it should have ?
The build sheet is commonly found under the "webbing" below the seat. At least on a bench anyway. If it's still there, be careful, because it's likely torn as it is. I made a copy, put it in a plastic sheet and put the original off to bed, never to be seen again.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
