Old 03-17-2011, 08:43 PM   #26
Goldfinger
Goldfinger's Avatar
Re: Optima battery
I go with the deep cycle marine optima. It will start no matter the conditions.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 03-17-2011, 09:47 PM   #27
1986swb
1986swb's Avatar
Re: Optima battery
I bought a red top Optima for the higher CCAs since I installed a new stereo system including driving two amps, a headset, four speakers and a subwoofer. The Optima came with a full 3-year, no-cost replacement (not pro-rated) warranty from NAPA. And I used all four battery posts as I had to do a ton of grounding for my sound system. So far, so good. No issues. She starts up strong.
1986 GMC Sierra Classic C1500 SWB
2006 GMC Yukon Denali
http://67-72chevytrucks.com/vboard/a...hp?albumid=977
1986swb is offline   Reply With Quote
Old 03-20-2011, 11:33 PM   #28
7T2
Active Member
7T2's Avatar
Re: Optima battery
Originally Posted by Sillyoldman View Post
Hook your charger up to a good battery, then run jumpers from it to your yellow top. There's a good chance it will come back.
I read that Hot Rod article too. Didn't work. The theory behind it is good, if your battery has that particular problem, but I believe I damaged mine beyond repair by getting frustrated and trying to jump-start it. I've tried reviving it any way you can, it just ain't coming back. Makes an impressive doorstop though...people would never know I'm broke.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 03-20-2011, 11:40 PM   #29
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Optima battery
Mine drains after 4 weeks or more if I don't run the truck. It will power equipment, but not turn over the motor. A quick charge and its up and running. The radio memory drains the battery. I use an auto battery charger. I set it at 2 amps. I charge it over night. The red top cranks over hard and fast on a full charge.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-21-2011, 02:56 AM   #30
BIG KRIS
BIG KRIS's Avatar
Re: Optima battery
Gonna give one a try.
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 03-21-2011, 04:12 AM   #31
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: Optima battery
I've never tried, but I've been told if ya drop a dead one it come back to life ?
the theory is that jars the jell , never seen it work but I had guys swear it does. mabey worht a try ?
also if I see a guy with an Optima door stop I assume he must be rich, all I can afford is a used brick, I use it as a door stop and a jackstand !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
