#26 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: rally rims
I dont think it is odd^^, the tires are pretty close to the same OD and it makes it so the front tires are in line with the rears, ya know like if you drive through water on a parking lot? they kinda line up, if you had 60 series on the front also, you wouldnt have the same rake and also the front would stick out just a little more than the rear. At least that is how I see it.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#27 |
Re: rally rims
Those are just on it for now so i can move it around.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#28 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: rally rims
Rally's are the only way to go! I like the Crager SS and Chromed Moons because like the Rally's,they're period correct and look good, but still only run a close second to the Rally's.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#29 |
Re: rally rims
ironangel what tire size?
#30 |
Re: rally rims
#31 |
Re: rally rims
Haven't bought the 225's yet for the van rally's, but the rear wheels look like they are sunk inwards more than the fronts with these tires. When i put the 295 drag radials on the rear and the 225's up front with the 6.5" rally, will it look better? Or will the rear wheels look like they are further inside than the fronts still? I heard that when you convert to disc brakes, it pushes the front wheels more outward...
#32 |
Re: rally rims
No, it will look fine with that combo. Do you have a 67-70 rearend or a 71-72 rearend?
#33 |
Re: rally rims
67-70
#34 |
Re: rally rims
Ok you will still look ok with the 6.5" van rims up front. The back spacing offset will still keep the front tires inward enough.
#35 |
Re: rally rims
Thanks. Here's a couple pictures with the new 225/70/15's by firestone. It did make alot of difference on how the rims and tires look in the fender wells.. Now all i need is the drag radials on the rear. What do you guys think about the spinners on the front. Kind of looks like they stick out a little bit to far. But the more i look at them outside, the more i like them. I thought about trying to find a couple that weren't quite as tall as these..
#36 |
Re: rally rims
here's some more
#37 |
Re: rally rims
Looks alot better. Gonna look sweet with the drag radials. I personall don't care for thespinners. I like the 88-98 center caps on these rallies.
#38 |
Re: rally rims
Ok, i just bought some 295/65/r15 and had them put on a set of 15x8" rims and they are toooo tall imo... So i'm going to exchange them for a couple of 295/55/r15 drag radials.... I think they will look about perfect.. Give me a couple weeks to get some pictures...
#39 |
Re: rally rims
Take some pics, lets see what you see! The ralleys do look good!
#40 |
Re: rally rims
Here's what i ended up with... 225/70/15's up front and 275/60/15's on back... 2.5" drop spindles, 4" springs on rear. I'm thinking about doing another 1" drop all the way around... What do you guys think?
#41 |
Re: rally rims
Here's a couple more...
#42 |
Re: rally rims
I'd like to have seen a bit more meat in the back, but it still looks good. Another 1" all around would be Super!!
#43 |
Re: rally rims
I tried to go bigger, but they looked out of place with 8" rims. If i had some 10" rims i would of went with a 295/55/r15. I think these look pretty good just for cruising and some car shows, then when i want to get serious i'll bolt on my hoosier 28/14.5/r15's which are mounted on my mickey thompson light weight rims....Of course, i'm kind of leaning away from the drag scene, and leaning more towards the car show scene.. Parts last alot longer!!! Don't get me wrong, i still want a 10sec. truck, just with airconditioning and power brakes and to be able to drive it anywhere..
#44 |
![]() Join Date: Feb 2008
Re: rally rims
Just thought I'd throw out the formula for everyone to calculate tire height for those who don't know it. I use this to compare tire sizes all the time.
First what the numbers mean: 255/70/15 = Tread width / Height ratio / Rim Tread width in millimeters = 25.6mm per in, Height ratio is 1 side so you double it, + rim (255/25.6) * .70*2 + 15 = 28.945313 This is easy on a cell phone calculator & easier to remember than you might think. 25.6 is the biggest number to just remember. Do that division, just mentally double the .7 to multiply by 1.4 then add the rim. Hope this helps some others.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
#45 | |
![]() Join Date: Jul 2010
Re: rally rims
#46 |
Re: rally rims
Well damn, I've been doing that wrong for a while!!
