#26 |
Update
I am getting closer to firing the truck up..........
Just recieved my driveline back from the driveline shop tonight. The driveshaft looks outstanding and fits like a glove!!!! Couldn't have been more happy about the results. I still need to complete my gas tank filler neck install, install carb & linkage, add fluids, wire up the electric fan relay and crimp a few wires. The weather is improving around here and I am getting car show fever! ![]()
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original |
#27 |
Re: Putting my 57' back together in the rainy PNW!!!
A couple wekends of free time and you will be driving it!
Posted via Mobile Device |
#28 |
did you get the right fan for it? get the fan info i sent you?
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#29 |
Yes, Speedway Motors delivered my replacement fan quickly. All of the numbers matched up to the ones you gave me. Thank you again!!!!! I also wanted to note that Speedway has excellent A++++ customer service! They were extremely helpful getting this fan business straightened out and quickly shipped out a new one. My correct 16" fan is now mounted and awaiting to be wired up.
#30 |
cool, glad it worked
#31 |
The weather just keeps getting better up here, I'm starting to really feel the pressure on this deadline, so the good weather has had me at it till nearly 10pm every night. My Fiancé has been working late hours too, so that helps keep me in the shop.
You still on track for the wedding NW Task Force? Posted via Mobile Device |
#32 | |
#33 |
Still plugging away at my project. It seems I have entered the little "details" stage. Buying nuts, bolts, hoses, adapters, fittings, etc to tie up loose ends. I am trying real hard to make my July 20th wedding deadline.
#34 |
Looks good. Sounds like you should make it.
Kim |
#35 |
Looking good!
#36 |
looking good
don't tally up the money spent on ''nuts, bolts, hoses, adapters, fittings, etc'' it will only hurt your feelings ![]()
#37 | |
Re: Update
Go to the wrecking yard and source bolts for a buck, make the deadline and replace them later in needed. |
#38 |
Elev8r Man
Re: Update
I get almost all my stainless hardware from Pomona swap meet and allensfasteners.com they have some really good prices and are very good with shipping. Once i get them I just sit down and polish them up so they are ready when I need to install them.
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
#39 |
Tonight I fired off the 57' for the first time! I am finally happy to hear some noise from the truck after over 12 years of sitting engineless. The engine runs on its own, but is running rough. The new carburetor needs a serious tuning and the timing requires adjusting. I have very little experience tuning engines and hope I can find someone locally who can lend a hand.
The engine is a 283cid with edelbrock carb & an HEI distributor.
#40 |
That's great man! Wish I was a little closer, I'd come give you a hand. We got mine fired up a couple weekends ago. Really lights the fire under you, doesn't it?!?
Congrats, keep up the good work! The big day is right around the corner, for both of us........ Gotta get these things on the road! Posted via Mobile Device |
#41 |
Congrats on the milestone. Least you know she runs.
Good luck on the deadline, sounds like you are making great time.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
#42 |
Congrats on getting it started.
I'm sure you'll get the bugs worked out. Kim |
#43 |
Congrats on getting it fired up, that's one hurdle jumped over.
#44 |
Congrats man, keep on a pushin!!!
#45 |
Thanks guys! Yeah, I was able to arrange for a car buddy to come over tomorrow and "time" the engine properly with a light. As far as carb tuning........still looking to recruit someone for that.
Need an opinion: Edelbrock 600cfm carb on a mostly stock 283cid (its too much carb, I know). What would be some recommendations for tuning it to run the 283 efficiently? Different metering rods & smaller jets? Thanks
#46 |
I finally was able to get the engine to run decent with the timing light. The engine idles in park and in gears just fine. The only thing I noticed is that in park the engine rpms jump slightly up and down. I hooked up a vacuum gauge to the intake........basically the engine is "hunting" between 12-15 Hg of vacuum while idling in park. I assume changing metering rods & jets will help calm this down? Any thoughts?
#47 |
congrats on your efforts sir - glad its runnin; - i am sure you will make the weddin;
you'll have the coolest ride goin down da road with the wife ,kudos to her too for spending time on a long hiatus love !. |
#48 |
Here it is folks!!!! Finally drove it yesterday! Took me approx. 1 year to reassemble/build to this point. My wedding is just around the corner!
#49 |
WOW great job !!!
i would like to congradulate you on all you efforts on ressurecting your 57 - great job and i think it will make one hell of a stunner at your wedding. sooooo congrats on the build and congrats on gettin hitched ! drive her well you earned it sir ! |
#50 |
Looks real sharp.
Congrats on getting it done. Kim |
