05-20-2011, 03:18 PM | #26 |
Moderator
Re: What heater core did you buy??
I used an aluminum. Works great, no leaks, no complaints.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-20-2011, 05:46 PM | #27 |
Not for my truck, but I just bought a core for my Chevelle from Napa and it is brass. I think the price was 45.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
05-21-2011, 02:14 AM | #28 |
toys'r'us
I finished my heater core install today.
I used duct seal for making my gaskets. Its a mouldable, waxy clay bar, that you can get from an electrical wholesaler. it says it can be used for constant use up to 190F. I just rolled it in my hands like playdough and made 3/8'' ropes of it. I normaly use it on power wires and refrigerant lines where they enter buildings. I sealed the core to the box and the box to the firewall. Then I sealed where the pipes stick out the box. I want every available btu in the cab. I filed off the sharp points of the bracket screws so if they did hit the heater core they would dent it but not pierce it but they cleared. No worries there they cleared. I used 2 hammers to thin out the bracket where it didnt fit under the pipe. I layed it across the face of a 4lb and hit it with the top edge of a ball peen. 3 second fix. Lots of crud inside the box. Cleaned everything on the firewall realy good with some gojo hand towels and hosed it all off. I think i might clean the whole engine bay now that theres a shiny spot. I fires the jimmy and it made way more heat and more flow than ever before Sorry i didnt take any pics i was in a hurry. Any questions just ask.
71 jimmy bone stock 350 sm465 33x12.5 rallies 79 caprice landau full load crate350 th350 lowered 20"wires 00 f150 reg cab sb 4x4 5.4L |
05-21-2011, 10:22 AM | #29 | |
05-21-2011, 01:55 PM | #30 |
I used an Autozone "Spectra" I think? I appreciated that it was a Canadian-made brand. My truck 1970 has a/c and I believe it was the original brass/copper type. The replacement was Aluminum and was a bit thinner diameter-wise, but I was able to still use the factory brackets that retain it in the housing. It went back in with ease. No leaks to report. This was done very recently.
MusicMan70 1961 GMC Suburban |
