Old 03-30-2011, 08:37 PM   #26
aggieguy713
aggieguy713's Avatar
Re: What's that sound?.....
Sorry to keep you guys in suspense, been away for a while. Sadly, took it to a friends shop, listened and watched for about an hour, and finally concluded it wasnthe thrust bearing in the engine. Result of a
Bad crank. Was also causing the harmonic balancer
To move forward when the clutch was pressed in. Way more then it should have. (talk about bad luck). Got the engine out, just gotta get a crank and put it back together.
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 03-30-2011, 09:32 PM   #27
snaus32
snaus32's Avatar
Originally Posted by Mr Chevorlet View Post
I know this is going to sound crazy, but i had a loud squealing noise on a fresh rebuild and it was driving me crazy. It took me a couple of hours to figure it out. And what it was i had all my breather holes on the valve covers blocked and the squealing noise was comming from the dipstick tube. and when i pulled the dipstick out it went away. Bottom line engine was creating to much vacum in the block.I put a breather cap on and never heard it again. This might be your case. but it happens
I had the exact same problem this year after my 327 rebuild! Breather fixed it
snaus32 is offline   Reply With Quote
Old 03-30-2011, 10:24 PM   #28
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You'll need to completely tear it down and get all the metal flakes out of it that the thrust bearing put in the oil passages and such. Did you break it in with ZDDP additive and as the cam manufacturer recommended?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-31-2011, 12:01 AM   #29
aggieguy713
Gary
Yeah, we looked, therewernt many flakes, but i will double check and look over everything. Yes, the lunati tech reccomended a special type of break in oil, i forget the name. Just a bad crank, unfortunatley.
Old 04-01-2011, 01:22 PM   #30
GASoline71
GASoline71's Avatar
If there are ANY flakes in the engine. They need to be washed out. Don't just check it and call it good. Or you'll be doin' this all over again very soon.
Gary
Old 04-01-2011, 02:38 PM   #31
Jessechop
Might I ask how you concluded it was a bad crank? There are so many variables that go into a problem like this, oil pump, pickup height, oil viscosity, dirt, inproper torque and on and on. Just wondering if there is a more tell tell sign of a truely "bad crank"
Jessechop is offline   Reply With Quote
Old 04-01-2011, 03:21 PM   #32
70STOVEBOLT
70STOVEBOLT's Avatar
Was the crank end play checked when the engine was built? If not, it's possible the side thrust surface on the crank could have been worn excessively. I would make sure to check the thrust surface on the block as well to make sure you don't have the same problem if you just replace the crank and reuse the block. Pull all the oil galley plugs and either clean them out with long brushes or blow them out with compressed air. The oil filter won't catch every piece of metal debris, so anywhere there was oil, there will most likely be debris also.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 04-01-2011, 04:42 PM   #33
mpotts64
mpotts64's Avatar
My '68 had a squealing noise on a new 283 with less than 600 miles, but it would only do it once in a while, come to find out the small yellow second wire to the starter had broken and then it would get against the block or starter and engage the starter while it was running, make a terrible noise, make sure your starter is not engaging, I taped it up and run it with the one main wire to the starter, no more problems
mpotts64 is offline   Reply With Quote
Old 04-01-2011, 08:43 PM   #34
aggieguy713
As i said, when the clutch was pressed in, it would cause the harmonic balancer to move forward about an inch. Only could mean one thing, bad thurst bearing. The crank we were told was good, and was fine to re use when we rebuilt. So we left it, bad idea. When we pulled the oil pan, it was more beat up then my truck was when i first got it. haha. We had a friend of mine, he rebuilds engines for a local performance shop lend us a hand. So that made it a bit easier.
Old 04-01-2011, 08:45 PM   #35
aggieguy713
Block was fine. There were HARDLY any, im saying, like 2 or three flakes at all, the thrust bearing was just bent-beat up from the crank.
Old 04-01-2011, 08:46 PM   #36
68gmsee
Active Member
68gmsee's Avatar
As i said, when the clutch was pressed in, it would cause the harmonic balancer to move forward about an inch...
Wow! One inch movement is a lot. Something definitely not right.
68gmsee is offline   Reply With Quote
Old 04-02-2011, 12:21 AM   #37
Frkypunk70
Frkypunk70's Avatar
I found metal once in my pan, it was from a worn lifter and cam. I rebuild the top end and flushed the engine thinking "how bad could it be" the engine lasted a total of 50 miles. Point is I never want to see metal in my pan. Just food for thought.
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. "
Frkypunk70 is offline   Reply With Quote
Old 04-03-2011, 11:52 AM   #38
biggestjohn
There is no way that a Harmonic Balancer can move an inch from the crank moving. If the crank moved that far, the rods would be garbage!!! Besides, there is not enough room between the mains and the crank to move like that. I would take a serious look at the harmonic balancer if its really moving like that.
biggestjohn is offline   Reply With Quote
Old 04-03-2011, 12:42 PM   #39
aggieguy713
Not a whole inch, but avery significant amount none the less.
