Old 11-06-2020, 12:26 PM   #26
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: Has anyone installed a Vintage Air Mark IV underdash unit?
Originally Posted by Andy4639 View Post
[B][COLOR="Red"]I was going to install this unit in my ramp truck but the 4 speed was going to make it unusable. It also wouldn't go in 1/3 gear.
Andy, I'm a column shifter type of guy so I'm good, but why dont you shift it a bit to the passenger side for clearance?
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 11-06-2020, 08:05 PM   #27
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Has anyone installed a Vintage Air Mark IV underdash unit?
Originally Posted by passthebuck View Post
Andy, I'm a column shifter type of guy so I'm good, but why don't you shift it a bit to the passenger side for clearance?
Because the factory heater box is in the way. I don't want to chop it up to make it fit.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-02-2022, 10:27 AM   #28
rs74
rs74's Avatar
I just got a truck that has one of these units in it. I haven't messed with it yet though.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 12-06-2022, 02:19 PM   #29
68 C10 Driver
I have a model similar to the Mark IV installed in my 68 Stepside. I will add photos when I get a chance this afternoon.
68 C10 Driver is offline   Reply With Quote
Old 12-06-2022, 04:49 PM   #30
68 C10 Driver
So this is my set-up, it is an ACME brand from around 1970, so I am considering it as period correct. As you can see it fit reasonably well, especially after I modified the interior heater box. The carpet just needs to be laid flat, so disregard the wrinkles.
Old 12-06-2022, 10:27 PM   #31
68 C10 Driver
I modified my interior heater box so it didn't occupy the area directly behind where the under dash unit is. Doing so reduced the amount that the unit sticks out from the dash.
