Old 04-27-2017, 01:10 PM   #26
DieselSJ
Re: CS-144 140amp alternator upgrade howto
Originally Posted by rfmaster View Post
The Upper Bracket modification can be avoided all together by going to a turnbuckle style tensioner which also doubles as a bracket.
//RF
Is that a March bracket? That looks like an awesome solution.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 04-27-2017, 03:02 PM   #27
gmachinz
I manufacture the CS144 adapter bracket kit for guys running a GM serpentine setup-another option for everyone.
gmachinz is offline   Reply With Quote
Old 04-30-2017, 03:42 AM   #28
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Wow, its been awhile. I swapped over to a single serp belt setup off a Camaro and used a bracket for the cs-144 for awhile. But I no longer have the CS-144. I have an AD-244 now.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 04-30-2017, 08:41 AM   #29
gmachinz
Nice!
Old 12-29-2020, 10:07 PM   #30
AustinBelair
Digging this up as well. I have an 88 and looking to upgrade to a higher output. I was told a 94 Buick Roadmaster Alt but it did not fit so I sent it back to Amazon. I didn't know the bracket needed modified. What notch is it? How do I convert to a better Alt? Mine has the Serpentine setup on the alt only
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 12-31-2020, 08:10 PM   #31
Pontiac1976
Pontiac1976's Avatar
This like has more info: CS-144 140amp alternator I hope this helps you. https://bowtieguy.proboards.com/thre...t-grade-cs144d
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-02-2021, 11:56 AM   #32
az79k5
I ran the 144 alternator with pretty good success. I put in the Derale 16928 fans and they pull a LOT of power. I upgraded to a 170a single wire alternator from Summit. You can still use the CS plug for the dash light, but it no longer needs an exciter wire (load) to charge.
https://www.summitracing.com/parts/PWM-7864
I also increased the charge and ground wires. They are slightly larger than the starter cable. I don’t remember the exact size.
At idle, the alternator wasn’t charging which can be a problem at long low RPM obstacles. I did some calculations with the charging RPM graphs and got a smaller puller (not by much) to have the alternator spin a little faster than stock. You HAVE to be aware of your top engine RPM and make sure the alternator spin speed does not reach its limit at the engines red line limit.
My engine may hit 3500 OR 4000 RPM rarely, but that will spin the alternator at a max 8000 RPM, which is below the alternator’s red line.
az79k5 is offline   Reply With Quote
Old 01-02-2021, 08:38 PM   #33
hatzie
Moderator
hatzie's Avatar
Good point about paying attention to the redlines of the accessories when you change the pulley ratios.
Your rad fans shouldn't run much with the exception of stop and go traffic. You can probably get away with the stock CS144.
8ga or 10ga charge wire from the ALT BAT terminal to the starter BAT terminal will work just fine.
If you're really pulling that much power you can get the four terminal AD244 from 2005 and earlier that doesn't require control from the PCM.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
