Old 05-20-2011, 05:49 PM   #26
COBALT
COBALT's Avatar
Re: Conversion Kit - Front Drum Brakes To Disc Brakes
No the race should be INSIDE the rotor for both inner and outer bearings ALREADY! If not take them to a machine shop and have them installed. For used rotors you can buy replacements but getting the old ones out and getting the new ones in should be done by someone with the right equipment. The bearing goes in against the race, then the washer, then the spindle nut.
The way you described breaking down one at a junk yard is exactly correct.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
