#26 |
Re: Show us some steering wheels
Badly cracked original + old 15" valve handle + body filler:
#27 |
Is that a 15" wheel? That looks great.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#28 |
Did you build that wheel yourself? It looks great. Do you have any pictures of it in the process of the build? I like the looks of the old wheels a lot, it’s just the size I don't care for that much. I like two of the design in the link I put in my post above, but a $300 wheel isn't in my near future. I wish I had the skills to make my own wheel.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#29 |
#30 |
Slow Build: It was more of an experiment after a few beers. I cut the hoop off the original wheel and ground back the plastic(?) to expose the metal framework of the wheel. I found a 15" valve handle at my place of employment and cleaned it up and just welded it on. Built the gaps back up with body filler and blended the arms into the hoop. Then tried to replicate the original texture with an engraving tool. It is far from perfect but will do until something better comes along.
#31 |
Just mocked it up yesterday
#32 |
US Army Veteran
![]() Join Date: Nov 2008
From post 1, pic 1:
Does anyone know who manufacturers this wheel and/or where it can be obtained?
1972 C10 Highlander - The making of a daily driver |
#33 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
Just chill'in..... Here ya go dawg! http://www.elitebillet.com/category.sc?categoryId=4
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 06-06-2011 at 08:16 PM. |
#34 |
US Army Veteran
Thanks 1bad!
That clip is hilarious! "Just chillin!"
#35 |
I keep it real! ha ha...
If you haven't noticed... I'm a crazy country boy from NC. ![]() ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 06-06-2011 at 09:09 PM. |
#36 |
#37 |
#38 |
heres the one that came with the 66...chevy II wheel....
![]() one side of the round horn ring was broken and messing with it ,it snapped all the way off ,but i did customize the center horn button so it doesnt say chevy II in the middle tho.....excuse the mess in cab thats all cleaned up now... ![]()
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
#39 |
I just put this Lumina wheel on mine. It's more comfortable for me but it blocks the speedo a little bit. It will work for awhile.
#40 |
#41 |
Just had to change the wheel. My column is from the late 60's to early 70's (tilt, non-locking, no key in column). It fits fine and the horn wire was easy to retro-fit.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 09-27-2011 at 03:32 PM. |
#42 |
Here's my mock up, lots of work to do still.
#43 |
![]() Join Date: Jun 2007
here is mine it is a comfort grip.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
#44 |
Here's mine i bought from the swamp-meet. anyways got it chromed, sanded, and primed it 3 times and painted it 3 times, wet sand everytime with #1000 and #2000 a bunch of times but not bad for a rattle can. what do you think?
#45 |
That looks awesome! Amazing what a little time and effort does.
#46 | |
Tony from Norcal |
#47 |
got this wheel from jmedero...i have a lot to do to it but itll be nice when im done...anyone got a horn ring in decent shape... this wheel is cut to fit the fancy set up for i think he said it was out of a 62 or a 63...mines messy too i was working on it when i took pics, sorry...
If you used to be...then i guess you never were. |
#48 |
What column is that? Looks great.
#49 |
#50 |
