04-21-2011, 10:00 AM | #26 |
Re: Brakes
no you must use the proper combination valve for the disc/drum system as there is a big difference between the dirstribution valve for the drum/drum system and the combination valve(in it is a proportion valve)that is for the disc/drum system
04-21-2011, 08:44 PM | #27 |
its all about the +6 inches
Re: Brakes
cdowns... I think that question was askinf about a disk/disk conversion.
If that is the case, you can try it, however, I would plan on getting a manually adjusted proportioning valve so you can fine tune when the rears will lock up. |
04-24-2011, 06:19 PM | #28 |
Re: Brakes
thanks for the info.That's what I will do then , install a manually adjusted proportioning valve for the rear.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
