Old 08-12-2011, 01:58 PM   #26
SSABMUD
SSABMUD's Avatar
Re: s10 swap...rim/tire configuration???
Originally Posted by rollinrooster View Post
Im not sure if 0 offset is centered and what that 7 offset is. But 18x8 and 20x8 should look pretty good provided you have the right offset. Here is a couple of pictures of mine with 20x8.5 with 6.25bs and 20x10 with 4.75bs.
I ordered up my rims last week with the minimum backspacing for the fronts at 4.00". With yours being 6.25", how close are you to the frame/a-arms with the tires while turning? I bought one of those Percy's wheel simulator thingamajigs and sure hope it is acurate when the rims are $3500.00! I used one of your truck photos to photoshop in my wheels to see what they look like. Very nice truck by the way.
Wade
SSABMUD is offline   Reply With Quote
Old 08-12-2011, 02:34 PM   #27
rollinrooster
rollinrooster's Avatar
Wade, what size wheels did youget up front? I have 2" spacers on mine in the front and everthing clears lock to lock
rollinrooster is offline   Reply With Quote
Old 08-12-2011, 03:05 PM   #28
SSABMUD
SSABMUD's Avatar
I am planning on running 245/40R-20 in front on a 20x8.5 and 295/40R-20 on a 20X10. I may go to a 305 in the rear as I have 2" wider rear fenders. I had to modify both inner fenders to to my custom headers, so I am a bit worried. I guess if worse comes to worse I can add a spacer if I have to. I like the tucked in look of the front wheels like on your truck. You have that thing nailed buddy.
Wade
Old 08-13-2011, 02:33 PM   #29
booger1949
if you gonna change the rearend any way why not put a camaro rearend in it instead of a 4x4
booger1949 is offline   Reply With Quote
