Old 06-30-2011, 11:36 PM   #26
mcbassin
Still Learning
mcbassin's Avatar
Re: Where did you buy your brake line kit? Did you like?
Originally Posted by ChevLoRay View Post
No pix, but the hard lines run down the inside of the right frame rail. There's a Tee that feeds a flex line that goes to the rear axle. Hard lines to each side and flex to the wheel cylinders.
Does that help?
Yes, that helps. I'm pretty sure I can figure them out after a bunch of trial and error. I'm just hoping to get visual reference before I start
the kit is 11 pieces and I would like to mount them in the "correct" location if you know what I mean.
mcbassin is offline   Reply With Quote
Old 06-30-2011, 11:49 PM   #27
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
If you need any help mike I can come help you I have done more than my fair share of these
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 07-01-2011, 12:16 AM   #28
mcbassin
Still Learning
mcbassin's Avatar
Thanks Kyle. I will definetly swap labor with you if you want some time. As long as you don't mind a slow old guy helping you.
The biggest problem is figuring out where all the bends should fit. I'm working on getting some pics from a member. Apparently, I forgot to order a few things too.....dumb
Old 07-01-2011, 12:52 AM   #29
BossHogg69
motor exploder
BossHogg69's Avatar
rear line pics. In the third pic you can see where I had to rotate the line to go around my rear swaybar bracket. It usually goes in the little clip on the axlehousing that is visible right beside the swaybar bracket that I used. Sorry, the pics are a little dark. This is a POL kit, if anyone cares. Also, I believe the hardlines run right into the wheel cylinders on a stock drum application. I have rear discs, so I had to use SS flex lines to reach the calipers (not shown).
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-01-2011, 12:55 AM   #30
BossHogg69
motor exploder
BossHogg69's Avatar
front pics, CPP kit. I buy what's on sale...
Adam
Old 07-01-2011, 01:08 AM   #31
BossHogg69
motor exploder
BossHogg69's Avatar
couple more pics of what I was talking about on the rearend. Sorry the pics are only thumbnail size, my computer is p!$$!ng me off right now with loading pics.
Adam
