04-22-2011, 12:13 AM | #26 |
Re: How to drop the front end? How much?
The only interference you will ever have will be on the lower control arm. You would never run into caliper problems, everything moves up with the spindle. Thats why the LCA is always the problem. I was running newer steelie wheels (from the 88-98 trucks) and because they have more backspacing then the rallies, I had problems not much though, was maybe a MM if that. You should have no problem at all with any 2" Spindle and stock rallies off of the 73-87 trucks.
04-22-2011, 12:17 AM | #27 |
Well 3" springs are going to ride like crap, You honestly should trim your stock springs before hand and see how it rides before you install the 3" springs. I have heard of peoples 3" springs popping out of the spring pockets. Plus, your going to have massive camber and its going to be a ***** to have it aligned properly not to mention tire wear.
04-22-2011, 12:20 AM | #28 |
Side note, Nice to know your going low the first time time around! Would suck to have to drop it, not be happy and drop it even more afterwards! Build it right the first time. (I should of followed my own rule but I got impatient not im rebuilding practically the whole truck! haha)
04-22-2011, 08:58 AM | #29 |
04-22-2011, 11:39 AM | #30 | |
Happy to be here
My "first" choice would be a 3" spindle and a stock spring with one coil cut off. Mod your lower A-arm if needed, and call it good.
04-22-2011, 11:54 AM | #31 | |
Belltech street performance shock. They are about 50$s each on stylintrucks.com |
04-22-2011, 11:57 AM | #32 |
I thought 3" Springs were shorter and had more coils to "compensate" for the difference? Am I reading it wrong?
04-22-2011, 12:18 PM | #33 |
I was noticing some of the springs were adverstised as not being progressive rate springs. The ones I ordered are progressive. Not sure if that's good or bad, though. Good, I hope. :-)
04-22-2011, 12:36 PM | #34 |
Happy to be here
Sorry, that should have been short not soft. Thinking and typing at the same time again....
04-22-2011, 12:38 PM | #35 |
Happy to be here
It may make a difference, but I doubt it. I have never had, or heard of any one having good results with a 3" spring on these trucks. No matter what, it is always best to get as much drop as possible from spindle first and spring next.
04-22-2011, 12:39 PM | #36 |
Well crap. Should I send the springs back, then???
04-22-2011, 12:44 PM | #37 |
Happy to be here
Its your call. I am just basing this on my experience as well as what has been posted here by several other.
04-22-2011, 01:01 PM | #38 |
Sounds like I'd better send em back, huh? I have stock springs, but I don't really dare use them. The truck was originally a six cylinder truck, and believe me when I tell you, this thing was beaten to a bloody pulp. Should I get 2" springs, then, and call it good? I am reluctant to cut my LCAs. Is that what y'all did to go as low as you have? I wish I had the funds to bag the truck, but it ain't cheap, or so it seems. 8 grand is a lotta ching.
04-22-2011, 01:03 PM | #39 | |
04-22-2011, 02:16 PM | #40 |
I would stay away from the 3" springs for sure. When I did my burb I was in the same shoes as you, I needed the cheapest option possible so I went with 3" springs MISTAKE! Now I am having to live with a bone jarring ride on a daily basis.
Jeff |
04-22-2011, 02:25 PM | #41 |
I have no problem sending the springs back. I would like to go low a la Muthstryker and N2Trux, though. How much would just bagging the front cost?
04-22-2011, 03:22 PM | #42 |
Okay, no bags. 2" springs and adjust from there. Aye.
04-22-2011, 05:00 PM | #43 |
Slugish
Been running 2.5 spindles & 3 in coils for 6-7 yr's now . My springs are Eibach brand . Dont know if that makes any difference or not. Was close getting the frontend aligned but it was done > at the limit of adjustment . If Idid it over again would go with 3 in spindles with 2.5 springs . My ride is tolerable , but is not a daily driver. Good luck .
04-22-2011, 10:42 PM | #44 |
04-29-2011, 08:36 PM | #45 |
Okay, 2 inch springs are on the way. Got some frame and suspension cleaning and painting to do. And some ball joint and bushing pressing. Anybody know a good place to get a stock replacement engine and headlight wire harness? I don't mean some painless wiring kit. I mean one that was made to factory specs, please! Thanks for all the advice so far. It's helping fill in some blanks for me!
04-29-2011, 09:29 PM | #46 |
Jag 66 you've gotta do a write up on how you lowered your truck! And also what size radial ta's are those??
04-29-2011, 11:58 PM | #47 |
I went with belltech 2'' coils and Western Chassis 2.5'' spindles up front, flip kit and shackles in the rear. I love the stance, BUT it rides rough, but that's because of the rough roads around here in CT. Long winter means lots of plowing, which means lots of potholes in the spring and just F'd up roads.
Certainly drivable, has to be, since it's my transportation, but if I were to do it again, I'd go 2/4. I've been to two alignment shops, just to make sure the first wasn't joking, but when you put a 2'' drop coil, the amount of shims needed for camber is rediculous. I could only imagine 3'' springs, probably wouldn't have enough room on the camber studs for enough shims! So I recommend the front drop I have for overall decent roads, and only a spindle drop for roads that are rough.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch Last edited by chevymotocross; 04-30-2011 at 12:00 AM. |
04-30-2011, 12:41 AM | #48 |
Happy to be here
Why not do a simple paddle valve system? It's a no frills deal, but it will get you low if thats the way you want to go. Here's what Way2low2 has to offer in the Suspension Marketplace- LINK
Street Machinery * way2lo2 * Paddle Valve Special For those of you looking for a simple air suspension system, I have exactly what you need. For the month of March we are running a Forum Special on a complete Paddle Valve system. * Here's what you get * * 4 way paddle gauge panel * * 4 airbags choice of dominator 2600 2500 or 9000 * * Series 380c compressor, pressure switch relay * *Firestone dual 3/8" NPT port 3 Gal. Tank* * 100 feet of line, and all the necessary fittings * * * $649.00 shipped * *
04-30-2011, 01:25 PM | #49 | |
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
04-30-2011, 05:57 PM | #50 |
My 87 has 2 and 1 half inch drop spindles , and 2 inch shorter coils in the front. A flip kit in the rear. It is to low in the front. I am installing stock coils in the front. I hope that will level the truck up. The Po did the work. He also cut the stop plate off of the lower A- Arm. Now the wheel will turn to much if I am not careful. I will have to live with that for now. It looks level in the drive way, but the drive way is slanted downhill.
