04-29-2011, 11:25 PM | #26 |
60-66 Nut
Re: 6lug rear to 5 lug rear
Yes, when converting the axle flanges from 6 lug to 5 lug, you should always plug the original holes. It is best to cut small round steel plugs and weld them in rather than try and fill them completely with weld.
04-30-2011, 03:31 AM | #27 |
I have an 86 chevy long bed parts truck. I haven't measured it yet but wondering if the width of the rearend is the same or close to a 65 chevy C10.
Thanks Jeff. |
04-30-2011, 08:29 AM | #28 |
04-30-2011, 10:19 PM | #29 |
On my 66 truck (stock rearend) I pulled the axles and drums. The machine shop drilled axles and drums for the price of $80 total. They also turned the end of the axle hub down, but they bolted the drum to the axle before machining.
Yancer race cars in Chandler AZ. I
I LOVE BURNOUTS:metal NO BOZO's |
05-03-2011, 10:52 PM | #30 |
What mods would be done to put a 73/87 rearend in a 1965 C-10.
05-03-2011, 11:27 PM | #31 |
Cut all the leaf spring bracketry off & weld on the truck arm mounting pads. Depending on ride height & wheel choice, you'll need to verify back spacing will work.
05-04-2011, 12:36 AM | #32 |
60-66 Nut
You'll also need to weld on a panhard bar mount. Unless you drop the rear a considerable amount, then you will want the panhard bar mount on the right trailing arm or just above it.
05-04-2011, 09:42 AM | #33 |
ok should i use the factory a arms an change ball joints since the newer trucks are 1.5" wider. or should i just bolt the whole thing in
05-04-2011, 09:50 AM | #34 |
'New' trucks aren't wider, the disc brake system is. They just increased the width of the rear end to keep things consistent. The a-arms are similar in length.
05-04-2011, 03:48 PM | #35 |
oh i thought they where actually wider
03-09-2012, 10:05 AM | #36 |
Any other views on the 6 lug-to-5 lug plug & redrill ??
03-09-2012, 10:39 AM | #37 |
Old re-drilled axles = older OE axles w/years of wear. New replacement swap axles = stronger + zero wear.
03-09-2012, 02:57 PM | #38 |
Just run 6 lug discs in the front
Posted via Mobile Device |
05-13-2015, 01:11 PM | #39 |
So, if i swap out my axles in my 1966, to aftermarket 5 lug. I will need drums from a 1971-1974?......RIGHT?? Are those the only year drums?
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
05-13-2015, 03:28 PM | #40 |
I get drums for a 71-72.
05-14-2015, 03:41 AM | #41 |
60-66 Nut
The '71-'72 drums will work, but you can also use the narrow drums (2" wide shoes) from up into the mid 70's.....'74 or so. Starting in '73, wider rear brakes (2.75" wide shoes) were available, but the backing plates have to be changed to be able to convert to the wider, better rear brakes.
