So Many Ideas, So Little Money
Brandon, I didn't see it answered, a SBC in the I-6 location moves weight back, its just a couple inches but evens the weight load more
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
Fabricate till you "puke"
I would say that a lot of the weight I shaved was the diff in 3/4 vs 1/2 ton suspension(unsprung weight). If you look into some of the aftermarket front crossmembers(Mustang II, or Jim Meyers), you can shave some weight......tube arms & coilovers are slick as he!! too! At the rear, a 4 link/coilover would save some weight & be very adjustable. As far as rear weight, you really need to keep all you can. My longhorn is a little longer,but has serious traction issues with an auto trans. I am setting the old truck up for a 6spd richmond......it will take a set of slicks to get her to hook up! Concentrate on the front weight.....glass clip, glass doors,alum rad,alum heads,waterpump,heater delete,relocated battery custom front crossmember,liteweight seats ect. You can shave a bunch of weight.....but after a while, it gets expensive. Good luck,crazyL
chevy2racr, thanks for explaining this. I'm still in the learning stages. Hehe. And will be for a looooooong time. Thanks
Brandon |
no problem brandon. in these trucks for traction and lightness gettin weight off the front and to the back is always good.. every little bit helps
Bryce
