Old 04-30-2011, 12:01 PM   #26
layingC10nK5
Re: Air Ride Setup Idea.
U can have a 6 valve, even a 4 valve set up with no air transfer. All u need to do is run a check valve before the bags and that will prevent the air from returning. Take a look at this pic...( not mine) found it on a previous thread.
layingC10nK5 is offline   Reply With Quote
Old 04-30-2011, 12:05 PM   #27
layingC10nK5
The best place for the check valve would be closest to the bag, that will keep the bag aired up in case of hose failure.
Old 04-30-2011, 04:52 PM   #28
67c10rustbuket
67c10rustbuket's Avatar
N2TRUX you are correct ,theres a million variables. Im sure a burban with worn out suspension could get some good body roll in the back.
I personally think 8 valves is the only way, but i started with 4 on my first truck and had minimal roll in the rear . thats just my experience. Assuming its a chevy truck with a properly setup rear 4link.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-30-2011, 05:19 PM   #29
67c10rustbuket
i guess if you wanted to you can do about anything with a bucket full of tees, fittings, and check valves.
what are we talking about $100 difference between a 6 valve setup and an 8 valve setup?? im guessing $40 per valve, 20 ft extra hose at $1 a foot retail, and a couple of fittings.
I know every penny counts i'm on a tight custom budget too.
Dan <---(my name)
Old 04-30-2011, 06:02 PM   #30
Jeffs70
Jeffs70's Avatar
I totally agree and have put my mind stuck at a 8 valve setup and just going to hold off would be the right way to go about it and have it done correctly all at once.
Jeffs70 is offline   Reply With Quote
